Siemens Mendix Studio Pro
  • CVSS v4 4.6
  • Equipment: Mendix Studio Pro
  • Vulnerability: Path Traversal
Successful exploitation of this vulnerability could allow an attacker to write or modify arbitrary files in directories outside a developer's project directory.
Siemens reports the following versions of Mendix Studio Pro integrated development environment are affected:
  • Siemens Mendix Studio Pro 8: Versions prior to V8.18.35
  • Siemens Mendix Studio Pro 9: Versions prior to V9.24.35
  • Siemens Mendix Studio Pro 10: Versions prior to V10.23.0
  • Siemens Mendix Studio Pro 10.6: Versions prior to V10.6.24
  • Siemens Mendix Studio Pro 10.12: Versions prior to V10.12.17
  • Siemens Mendix Studio Pro 10.18: Versions prior to V10.18.7
  • Siemens Mendix Studio Pro 11: All versions
3.2.1 IMPROPER LIMITATION OF A PATHNAME TO A RESTRICTED DIRECTORY ('PATH TRAVERSAL') CWE-22
A zip path traversal vulnerability exists in the module installation process of Studio Pro. By crafting a malicious module and distributing it via (for example) the Mendix Marketplace, an attacker could write or modify arbitrary files in directories outside a developer's project directory upon module installation.
CVE-2025-40592 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.1 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:H/PR:N/UI:R/S:C/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-40592. A base score of 4.6 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:H/AT:N/PR:N/UI:A/VC:N/VI:N/VA:N/SC:N/SI:H/SA:N).
Siemens has released new versions for several affected products and recommends users update to the latest versions. Siemens is preparing further fixed versions and recommends specific countermeasures for products where fixes are not, or not yet, available:
Siemens recommends that users do not install untrusted/unverified modules in Studio Pro projects.
For more information see the associated Siemens security advisory SSA-627195 in HTML and CSAF.
  • June 17, 2025: Initial Republication of Siemens SSA-627195
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-168-01
