Opcenter RDnL is affected by missing authentication in critical function in ‘ActiveMQ Artemis’. An unauthenticated attacker within the adjacent network could use the Core protocol to force a target broker to establish an outbound Core federation connection to an attacker-controlled rogue broker. This could potentially result in availability impacts or message injection into any queue via the rogue broker. Breaking the integrity of a message has a low impact due to missing auto refresh functionality and it does not contain any confidential information. ActiveMQ Artemis has released a new version and Siemens recommends to update to the latest version.
The following versions of Siemens Opcenter RDnL are affected:
- Opcenter RDnL vers:all/*
| v3 7.1 | Siemens | Siemens Opcenter RDnL | Missing Authentication for Critical Function |
CVE-2026-27446
Missing Authentication for Critical Function (CWE-306) vulnerability in Apache Artemis, Apache ActiveMQ Artemis. An unauthenticated remote attacker can use the Core protocol to force a target broker to establish an outbound Core federation connection to an attacker-controlled rogue broker. This could potentially result in message injection into any queue and/or message exfiltration from any queue via the rogue broker. This impacts environments that allow both: - incoming Core protocol connections from untrusted sources to the broker - outgoing Core protocol connections from the broker to untrusted targets
Opcenter RDnL
Implement and deploy a Core interceptor to deny all Core downstream federation connect packets. Such packets have a type of (int) -16 or (byte) 0xfffffff0. Documentation for interceptors is available at https://artemis.apache.org/components/artemis/documentation/latest/intercepting-operations.html .
Remove Core protocol support from any acceptor receiving connections from untrusted sources. Incoming Core protocol connections are supported by default via the "artemis" acceptor listening on port 61616. See the "protocols" URL parameter configured for the acceptor. An acceptor URL without this parameter supports all protocols by default, including Core
Use two-way SSL (i.e. certificate-based authentication) in order to force every client to present the proper SSL certificate when establishing a connection before any message protocol handshake is attempted. This will prevent unauthenticated exploitation of this vulnerability
Update to Apache Artemis version 2.52.0 or later version
| 3.1 | 7.1 | HIGH | CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:L/A:H |
This ICSA is a verbatim republication of Siemens ProductCERT SSA-085541 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
| 2026-05-12 | 1 | Publication Date |
| 2026-05-14 | 2 | Initial CISA Republication of Siemens ProductCERT SSA-085541 advisory |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-134-09
