Siemens OZW Web Servers
  • CVSS v4 10.0
  • Equipment: OZW Web Servers
  • Vulnerabilities: Improper Neutralization of Special Elements used in an OS Command ('OS Command Injection'), Improper Neutralization of Special Elements used in an SQL Command ('SQL Injection')
Successful exploitation of these vulnerabilities could allow an attacker to execute arbitrary code on the device with root privileges.
  • OZW672: Versions prior to V8.0 (CVE-2025-26389)
  • OZW672: Versions prior to V6.0 (CVE-2025-26390)
  • OZW772: Versions prior to V8.0 (CVE-2025-26389)
  • OZW772: Versions prior to V6.0 (CVE-2025-26390)
The web service in affected devices does not sanitize the input parameters required for the ex-exportDiagramPage endpoint. This could allow an unauthenticated remote attacker to execute arbitrary code with root privileges.
CVE-2025-26389 has been assigned to this vulnerability. A CVSS v3.1 base score of 10.0 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-26389. A base score of 10.0 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
3.2.2 IMPROPER NEUTRALIZATION OF SPECIAL ELEMENTS USED IN AN SQL COMMAND ('SQL INJECTION') CWE-89
The web service of affected devices is vulnerable to SQL injection when checking authentication data. This could allow an unauthenticated remote attacker to bypass the check and authenticate as Administrator user.
CVE-2025-26390 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-26390. A base score of 9.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
RandoriSec reported these vulnerabilities to Siemens reported these vulnerabilities to CISA.
For more information see the associated Siemens security advisory SSA-047424 in HTML and CSAF.
  • May 15, 2025: Initial Republication of Siemens SSA-047424
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-135-10
