Siemens RUGGEDCOM CROSSBOW Station Access Controller (SAC)
RUGGEDCOM CROSSBOW Station Access Controller (SAC) contains a vulnerability that could allow an attacker to achieve arbitrary code execution and to create a denial of service condition. Siemens has released a new version for RUGGEDCOM CROSSBOW Station Access Controller (SAC) and recommends to update to the latest version.
The following versions of Siemens RUGGEDCOM CROSSBOW Station Access Controller (SAC) are affected:
  • RUGGEDCOM CROSSBOW Station Access Controller (SAC) vers:intdot/<5.8 (CVE-2025-6965)
v3 7.7 Siemens Siemens RUGGEDCOM CROSSBOW Station Access Controller (SAC) Numeric Truncation Error
CVE-2025-6965
There exists a vulnerability in SQLite versions before 3.50.2 where the number of aggregate terms could exceed the number of columns available. This could lead to a memory corruption issue. We recommend upgrading to version 3.50.2 or above.
Update to V5.8 or later version
https://support.industry.siemens.com/cs/ww/en/view/110000841/
Relevant CWE: CWE-197 Numeric Truncation Error
3.1 7.7 HIGH CVSS:3.1/AV:N/AC:H/PR:L/UI:N/S:C/C:L/I:H/A:L
This ICSA is a verbatim republication of Siemens ProductCERT SSA-225816 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-04-14
2026-04-14 1 Publication Date
2026-04-21 2 Initial CISA Republication of Siemens ProductCERT SSA-225816 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-111-08
