- CVSS v4 9.4
- Vendor: Siemens
- Equipment: RUGGEDCOM ROX II
- Vulnerabilities: Client-Side Enforcement of Server-Side Security
Successful exploitation of these vulnerabilities could allow an attacker with a legitimate, highly privileged account on the web interface to get privileged code execution in the underlying OS of the affected products.
- RUGGEDCOM ROX MX5000: Versions prior to V2.16.5
- RUGGEDCOM ROX RX1536: Versions prior to V2.16.5
- RUGGEDCOM ROX RX5000: Versions prior to V2.16.5
- RUGGEDCOM ROX MX5000RE: Versions prior to V2.16.5
- RUGGEDCOM ROX RX1400: Versions prior to V2.16.5
- RUGGEDCOM ROX RX1500: Versions prior to V2.16.5
- RUGGEDCOM ROX RX1501: Versions prior to V2.16.5
- RUGGEDCOM ROX RX1510: Versions prior to V2.16.5
- RUGGEDCOM ROX RX1511: Versions prior to V2.16.5
- RUGGEDCOM ROX RX1512: Versions prior to V2.16.5
- RUGGEDCOM ROX RX1524: Versions prior to V2.16.5
3.2.1 CLIENT-SIDE ENFORCEMENT OF SERVER-SIDE SECURITY CWE-602
The 'ping' tool in the web interface of affected devices is vulnerable to command injection due to missing server side input sanitation. This could allow an authenticated remote attacker to execute arbitrary code with root privileges.
CVE-2025-32469 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.9 has been assigned; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-32469. A base score of 9.4 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
3.2.2 CLIENT-SIDE ENFORCEMENT OF SERVER-SIDE SECURITY CWE-602
The 'tcpdump' tool in the web interface of affected devices is vulnerable to command injection due to missing server side input sanitation. This could allow an authenticated remote attacker to execute arbitrary code with root privileges.
CVE-2025-33024 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.9 has been assigned; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-33024. A base score of 9.4 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
3.2.3 CLIENT-SIDE ENFORCEMENT OF SERVER-SIDE SECURITY CWE-602
The 'traceroute' tool in the web interface of affected devices is vulnerable to command injection due to missing server side input sanitation. This could allow an authenticated remote attacker to execute arbitrary code with root privileges.
CVE-2025-33025 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.9 has been assigned; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-33025. A base score of 9.4 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
Siemens reported these vulnerabilities to CISA.
- All affected products: Update to V2.16.5 or later version
For more information see the associated Siemens security advisory SSA-301229 in HTML and CSAF.
- May 15, 2025: Initial Republication of Siemens SSA-301229
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-135-17
