Siemens Ruggedcom Rox
Ruggedcom Rox contains an input validation vulnerability in the Scheduler functionality that could allow an authenticated remote attacker to execute arbitrary commands with root privileges on the underlying operating system. Siemens has released new versions for the affected products and recommends to update to the latest versions.
The following versions of Siemens Ruggedcom Rox are affected:
  • RUGGEDCOM ROX MX5000 vers:intdot/<2.17.1
  • RUGGEDCOM ROX MX5000RE vers:intdot/<2.17.1
  • RUGGEDCOM ROX RX1400 vers:intdot/<2.17.1
  • RUGGEDCOM ROX RX1500 vers:intdot/<2.17.1
  • RUGGEDCOM ROX RX1501 vers:intdot/<2.17.1
  • RUGGEDCOM ROX RX1510 vers:intdot/<2.17.1
  • RUGGEDCOM ROX RX1511 vers:intdot/<2.17.1
  • RUGGEDCOM ROX RX1512 vers:intdot/<2.17.1
  • RUGGEDCOM ROX RX1524 vers:intdot/<2.17.1
  • RUGGEDCOM ROX RX1536 vers:intdot/<2.17.1
  • RUGGEDCOM ROX RX5000 vers:intdot/<2.17.1
v3 9.1 Siemens Siemens Ruggedcom Rox Improper Neutralization of Special Elements used in an OS Command ('OS Command Injection')
CVE-2025-40949
Affected devices do not properly sanitize user-supplied input in the Scheduler functionality of the Web UI, allowing commands to be injected into the task scheduling backend. This could allow an authenticated remote attacker to execute arbitrary commands with root privileges on the underlying operating system.
RUGGEDCOM ROX MX5000, RUGGEDCOM ROX MX5000RE, RUGGEDCOM ROX RX1400, RUGGEDCOM ROX RX1500, RUGGEDCOM ROX RX1501, RUGGEDCOM ROX RX1510, RUGGEDCOM ROX RX1511, RUGGEDCOM ROX RX1512, RUGGEDCOM ROX RX1524, RUGGEDCOM ROX RX1536, RUGGEDCOM ROX RX5000
Update to V2.17.1 or later version
https://support.industry.siemens.com/cs/ww/en/view/110002017/
3.1 9.1 CRITICAL CVSS:3.1/AV:N/AC:L/PR:H/UI:N/S:C/C:H/I:H/A:H
  • Emmanuel Zhou, Rick Wyble, Mehemt Balta, and Adam Robbie of Palo Alto Networks OT Threat Research Lab reported this vulnerability to Siemens.
This ICSA is a verbatim republication of Siemens ProductCERT SSA-081142 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-05-12
2026-05-12 1 Publication Date
2026-05-14 2 Initial CISA Republication of Siemens ProductCERT SSA-081142 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-134-12
