Siemens SCALANCE and RUGGEDCOM
  • CVSS v4 7.1
  • Equipment: SCALANCE and RUGGEDCOM
  • Vulnerabilities: Incorrect Authorization, Concurrent Execution using Shared Resource with Improper Synchronization ('Race Condition')
Successful exploitation of these vulnerabilities could allow an attacker to circumvent authorization checks and perform actions that exceed the permissions of the "guest" role.
  • Siemens RUGGEDCOM RST2428P (6GK6242-6PA00): All versions prior to V3.2
  • Siemens SCALANCE XCM324 (6GK5324-8TS01-2AC2): All versions prior to V3.2
  • Siemens SCALANCE XCM328 (6GK5328-4TS01-2AC2): All versions prior to V3.2
  • Siemens SCALANCE XCM332 (6GK5332-0GA01-2AC2): All versions prior to V3.2
  • Siemens SCALANCE XR302-32 (6GK5334-5TS00-2AR3): All versions prior to V3.2
  • Siemens SCALANCE XR302-32 (6GK5334-5TS00-3AR3): All versions prior to V3.2
  • Siemens SCALANCE XR302-32 (6GK5334-5TS00-4AR3): All versions prior to V3.2
  • Siemens SCALANCE XR322-12 (6GK5334-3TS00-2AR3): All versions prior to V3.2
  • Siemens SCALANCE XR322-12 (6GK5334-3TS00-3AR3): All versions prior to V3.2
  • Siemens SCALANCE XR322-12 (6GK5334-3TS00-4AR3): All versions prior to V3.2
  • Siemens SCALANCE XR326-8 (6GK5334-2TS00-2AR3): All versions prior to V3.2
  • Siemens SCALANCE XC316-8 (6GK5324-8TS00-2AC2): All versions prior to V3.2
  • Siemens SCALANCE XR326-8 (6GK5334-2TS00-3AR3): All versions prior to V3.2
  • Siemens SCALANCE XR326-8 (6GK5334-2TS00-4AR3): All versions prior to V3.2
  • Siemens SCALANCE XR326-8 EEC (6GK5334-2TS00-2ER3): All versions prior to V3.2
  • Siemens SCALANCE XR502-32 (6GK5534-5TR00-2AR3): All versions prior to V3.2
  • Siemens SCALANCE XR502-32 (6GK5534-5TR00-3AR3): All versions prior to V3.2
  • Siemens SCALANCE XR502-32 (6GK5534-5TR00-4AR3): All versions prior to V3.2
  • Siemens SCALANCE XR522-12 (6GK5534-3TR00-2AR3): All versions prior to V3.2
  • Siemens SCALANCE XR522-12 (6GK5534-3TR00-3AR3): All versions prior to V3.2
  • Siemens SCALANCE XR522-12 (6GK5534-3TR00-4AR3): All versions prior to V3.2
  • Siemens SCALANCE XR526-8 (6GK5534-2TR00-2AR3): All versions prior to V3.2
  • Siemens SCALANCE XC324-4 (6GK5328-4TS00-2AC2): All versions prior to V3.2
  • Siemens SCALANCE XR526-8 (6GK5534-2TR00-3AR3): All versions prior to V3.2
  • Siemens SCALANCE XR526-8 (6GK5534-2TR00-4AR3): All versions prior to V3.2
  • Siemens SCALANCE XRH334 (24 V DC, 8xFO, CC) (6GK5334-2TS01-2ER3): All versions prior to V3.2
  • Siemens SCALANCE XRM334 (2x230 V AC, 8xFO) (6GK5334-2TS01-4AR3): All versions prior to V3.2
  • Siemens SCALANCE XRM334 (2x230 V AC, 12xFO) (6GK5334-3TS01-4AR3): All versions prior to V3.2
  • Siemens SCALANCE XRM334 (2x230V AC, 2x10G, 24xSFP, 8xSFP+) (6GK5334-5TS01-4AR3): All versions prior to V3.2
  • Siemens SCALANCE XRM334 (24 V DC, 8xFO) (6GK5334-2TS01-2AR3): All versions prior to V3.2
  • Siemens SCALANCE XRM334 (24 V DC, 12xFO) (6GK5334-3TS01-2AR3): All versions prior to V3.2
  • Siemens SCALANCE XRM334 (24V DC, 2x10G, 24xSFP, 8xSFP+) (6GK5334-5TS01-2AR3): All versions prior to V3.2
  • Siemens SCALANCE XRM334 (230 V AC, 8xFO) (6GK5334-2TS01-3AR3): All versions prior to V3.2
  • Siemens SCALANCE XC324-4 EEC (6GK5328-4TS00-2EC2): All versions prior to V3.2
  • Siemens SCALANCE XRM334 (230 V AC, 12xFO) (6GK5334-3TS01-3AR3): All versions prior to V3.2
  • Siemens SCALANCE XRM334 (230V AC, 2x10G, 24xSFP, 8xSFP+) (6GK5334-5TS01-3AR3): All versions prior to V3.2
  • Siemens SCALANCE XC332 (6GK5332-0GA00-2AC2): All versions prior to V3.2
  • Siemens SCALANCE XC416-8 (6GK5424-8TR00-2AC2): All versions prior to V3.2
  • Siemens SCALANCE XC424-4 (6GK5428-4TR00-2AC2): All versions prior to V3.2
  • Siemens SCALANCE XC432 (6GK5432-0GR00-2AC2): All versions prior to V3.2
  • Siemens SCALANCE XCH328 (6GK5328-4TS01-2EC2): All versions prior to V3.2
3.2.1 INCORRECT AUTHORIZATION CWE-863
The "Load Rollback" functionality in the web interface of affected products contains an incorrect authorization check vulnerability. This could allow an authenticated remote attacker with a "guest" role to make the affected product roll back configuration changes made by privileged users.
CVE-2025-40567 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-40567. A base score of 7.1 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.2 INCORRECT AUTHORIZATION CWE-863
An internal session termination functionality in the web interface of affected products contains an incorrect authorization check vulnerability. This could allow an authenticated remote attacker with a "guest" role to terminate legitimate users' sessions.
CVE-2025-40568 has been assigned to this vulnerability. A CVSS v3.1 base score of 4.3 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:N/A:L).
A CVSS v4 score has also been calculated for CVE-2025-40568. A base score of 5.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.3 CONCURRENT EXECUTION USING SHARED RESOURCE WITH IMPROPER SYNCHRONIZATION ('RACE CONDITION') CWE-362
The "Load Configuration from Local PC" functionality in the web interface of affected products contains a race condition vulnerability. This could allow an authenticated remote attacker to make the affected product load an attacker controlled configuration instead of the legitimate one. Successful exploitation requires that a legitimate administrator invokes the functionality and the attacker wins the race condition.
CVE-2025-40569 has been assigned to this vulnerability. A CVSS v3.1 base score of 4.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:H/PR:L/UI:R/S:U/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-40569. A base score of 5.9 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:H/VA:N/SC:N/SI:N/SA:N).
Siemens reported these vulnerabilities to CISA.
  • RUGGEDCOM RST2428P (6GK6242-6PA00), SCALANCE XC316-8 (6GK5324-8TS00-2AC2), SCALANCE XC324-4 (6GK5328-4TS00-2AC2), SCALANCE XC324-4 EEC (6GK5328-4TS00-2EC2), SCALANCE XC332 (6GK5332-0GA00-2AC2), SCALANCE XC416-8 (6GK5424-8TR00-2AC2), SCALANCE XC424-4 (6GK5428-4TR00-2AC2), SCALANCE XC432 (6GK5432-0GR00-2AC2), SCALANCE XCH328 (6GK5328-4TS01-2EC2), SCALANCE XCM324 (6GK5324-8TS01-2AC2), SCALANCE XCM328 (6GK5328-4TS01-2AC2), SCALANCE XR302-32 (6GK5334-5TS00-2AR3), SCALANCE XR302-32 (6GK5334-5TS00-3AR3), SCALANCE XR302-32 (6GK5334-5TS00-4AR3), SCALANCE XR322-12 (6GK5334-3TS00-2AR3), SCALANCE XR322-12 (6GK5334-3TS00-3AR3), SCALANCE XR322-12 (6GK5334-3TS00-4AR3), SCALANCE XR326-8 (6GK5334-2TS00-2AR3), SCALANCE XR326-8 (6GK5334-2TS00-3AR3), SCALANCE XR326-8 (6GK5334-2TS00-4AR3), SCALANCE XR326-8 EEC (6GK5334-2TS00-2ER3), SCALANCE XR502-32 (6GK5534-5TR00-2AR3), SCALANCE XR502-32 (6GK5534-5TR00-3AR3), SCALANCE XR502-32 (6GK5534-5TR00-4AR3), SCALANCE XR522-12 (6GK5534-3TR00-2AR3), SCALANCE XR522-12 (6GK5534-3TR00-3AR3), SCALANCE XR522-12 (6GK5534-3TR00-4AR3), SCALANCE XR526-8 (6GK5534-2TR00-2AR3), SCALANCE XR526-8 (6GK5534-2TR00-3AR3), SCALANCE XR526-8 (6GK5534-2TR00-4AR3), SCALANCE XRH334 (24 V DC, 8xFO, CC) (6GK5334-2TS01-2ER3), SCALANCE XRM334 (2x230 V AC, 8xFO) (6GK5334-2TS01-4AR3), SCALANCE XRM334 (2x230 V AC, 12xFO) (6GK5334-3TS01-4AR3), SCALANCE XRM334 (2x230V AC, 2x10G, 24xSFP, 8xSFP+) (6GK5334-5TS01-4AR3), SCALANCE XRM334 (24 V DC, 8xFO) (6GK5334-2TS01-2AR3), SCALANCE XRM334 (24 V DC, 12xFO) (6GK5334-3TS01-2AR3), SCALANCE XRM334 (24V DC, 2x10G, 24xSFP, 8xSFP+) (6GK5334-5TS01-2AR3), SCALANCE XRM334 (230 V AC, 8xFO) (6GK5334-2TS01-3AR3), SCALANCE XRM334 (230 V AC, 12xFO) (6GK5334-3TS01-3AR3), SCALANCE XRM334 (230V AC, 2x10G, 24xSFP, 8xSFP+) (6GK5334-5TS01-3AR3): Update to V3.2 or later version
  • SCALANCE XCM332 (6GK5332-0GA01-2AC2): Update to V3.2 or later version
For more information see the associated Siemens security advisory SSA-693776 in HTML and CSAF.
  • June 12, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-162-04
