Siemens SCALANCE LPE9403
  • CVSS v4 8.5
  • ATTENTION: Exploitable from adjacent network/low attack complexity
  • Equipment: SCALANCE LPE9403
  • Vulnerabilities: Incorrect Permission Assignment for Critical Resource, Path Traversal: '.../...//', Use of Uninitialized Variable, NULL Pointer Dereference, Out-of-bounds Read, Stack-based Buffer Overflow, Authentication Bypass Using an Alternate Path or Channel, Improper Neutralization of Special Elements used in an OS Command ('OS Command Injection'), Cleartext Transmission of Sensitive Information
Successful exploitation of these vulnerabilities could affect the confidentiality, integrity, and availability of affected devices.
  • SCALANCE LPE9403 (6GK5998-3GS00-2AC2): All versions (CVE-2025-40572, CVE-2025-40573, CVE-2025-40574, CVE-2025-40575, CVE-2025-40576, CVE-2025-40577, CVE-2025-40578, CVE-2025-40579, CVE-2025-40580)
  • SCALANCE LPE9403 (6GK5998-3GS00-2AC2): All versions (CVE-2025-40581, CVE-2025-40582, CVE-2025-40583)
3.2.1 INCORRECT PERMISSION ASSIGNMENT FOR CRITICAL RESOURCE CWE-732
Affected devices do not properly assign permissions to critical resources. This could allow a non-privileged local attacker to access sensitive information stored on the device.
CVE-2025-40572 has been assigned to this vulnerability. A CVSS v3 base score of 5.5 has been assigned; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-40572. A base score of 6.8 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:L/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
3.2.2 PATH TRAVERSAL: '.../...//' CWE-35
Affected devices are vulnerable to path traversal attacks. This could allow a privileged local attacker to restore backups that are outside the backup folder.
CVE-2025-40573 has been assigned to this vulnerability. A CVSS v3 base score of 4.4 has been assigned; the CVSS vector string is
(CVSS:3.1/AV:L/AC:L/PR:H/UI:N/S:U/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-40573. A base score of 6.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:H/UI:N/VC:N/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.3 INCORRECT PERMISSION ASSIGNMENT FOR CRITICAL RESOURCE CWE-732
Affected devices do not properly assign permissions to critical resources. This could allow a non-privileged local attacker to interact with the backup manager service.
CVE-2025-40574 has been assigned to this vulnerability. A CVSS v3 base score of 7.8 has been assigned; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-40574. A base score of 8.5 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.4 USE OF UNINITIALIZED VARIABLE CWE-457
Affected devices do not properly validate incoming Profinet packets. An unauthenticated remote attacker can exploit this flaw by sending a specially crafted malicious packet, which leads to a crash of the dcpd process.
CVE-2025-40575 has been assigned to this vulnerability. A CVSS v3 base score of 4.3 has been assigned; the CVSS vector string is (CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L).
A CVSS v4 score has also been calculated for CVE-2025-40574. A base score of 5.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:A/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:L/SC:N/SI:N/SA:N).
3.2.5 NULL POINTER DEREFERENCE CWE-476
CVE-2025-40576 has been assigned to this vulnerability. A CVSS v3 base score of 4.3 has been assigned; the CVSS vector string is (CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L).
A CVSS v4 score has also been calculated for CVE-2025-40576. A base score of 5.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:A/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:L/SC:N/SI:N/SA:N).
3.2.6 OUT-OF-BOUNDS READ CWE-125
CVE-2025-40577 has been assigned to this vulnerability. A CVSS v3 base score of 4.3 has been assigned; the CVSS vector string is (CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L).
A CVSS v4 score has also been calculated for CVE-2025-40577. A base score of 5.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:A/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:L/SC:N/SI:N/SA:N).
3.2.7 OUT-OF-BOUNDS READ CWE-125
Affected devices do not properly handle multiple incoming Profinet packets received in rapid succession. An unauthenticated remote attacker can exploit this flaw by sending multiple packets in a very short time frame, which leads to a crash of the dcpd process.
CVE-2025-40578 has been assigned to this vulnerability. A CVSS v3 base score of 4.3 has been assigned; the CVSS vector string is (CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L).
A CVSS v4 score has also been calculated for CVE-2025-40578. A base score of 5.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:A/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:L/SC:N/SI:N/SA:N).
3.2.8 STACK-BASED BUFFER OVERFLOW CWE-121
Affected devices are vulnerable to a stack-based buffer overflow. This could allow a non-privileged local attacker to execute arbitrary code on the device or to cause a denial of service condition.
CVE-2025-40579 has been assigned to this vulnerability. A CVSS v3 base score of 6.7 has been assigned; the CVSS vector string is (CVSS:3.1/AV:L/AC:H/PR:L/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-40579. A base score of 5.4 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:H/AT:N/PR:L/UI:P/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.9 STACK-BASED BUFFER OVERFLOW CWE-121
CVE-2025-40580 has been assigned to this vulnerability. A CVSS v3 base score of 6.7 has been assigned; the CVSS vector string is (CVSS:3.1/AV:L/AC:H/PR:L/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-40580. A base score of 5.4 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:H/AT:N/PR:L/UI:P/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.10 AUTHENTICATION BYPASS USING AN ALTERNATE PATH OR CHANNEL CWE-288
Affected devices are vulnerable to an authentication bypass. This could allow a non-privileged local attacker to bypass the authentication of the SINEMA Remote Connect Edge Client, and to read and modify the configuration parameters.
CVE-2025-40581 has been assigned to this vulnerability. A CVSS v3 base score of 7.1 has been assigned; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-40581. A base score of 8.4 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.11 IMPROPER NEUTRALIZATION OF SPECIAL ELEMENTS USED IN AN OS COMMAND ('OS COMMAND INJECTION') CWE-78
Affected devices do not properly sanitize configuration parameters. This could allow a non-privileged local attacker to execute root commands on the device.
CVE-2025-40582 has been assigned to this vulnerability. A CVSS v3 base score of 7.8 has been assigned; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-40582. A base score of 8.5 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.12 CLEARTEXT TRANSMISSION OF SENSITIVE INFORMATION CWE-319
Affected devices do transmit sensitive information in cleartext. This could allow a privileged local attacker to retrieve this sensitive information.
CVE-2025-40583 has been assigned to this vulnerability. A CVSS v3 base score of 4.4 has been assigned; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:H/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-40583. A base score of 6.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:H/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
Luca Borzacchiello from Nozomi Networks reported these vulnerabilities to Siemens.
Siemens reported these vulnerabilities to CISA.
  • SCALANCE LPE9403 (6GK5998-3GS00-2AC2): Currently no fix is available
  • SCALANCE LPE9403 (6GK5998-3GS00-2AC2)(CVE-2025-40572, CVE-2025-40573, CVE-2025-40574, CVE-2025-40579, CVE-2025-40580, CVE-2025-40581, CVE-2025-40582, CVE-2025-40583): Restrict access to authorized and trusted personal only
  • SCALANCE LPE9403 (6GK5998-3GS00-2AC2)(CVE-2025-40575, CVE-2025-40576, CVE-2025-40577, CVE-2025-40578): Disable the Profinet Discovery and Configuration Protocol (DCP) service
  • SCALANCE LPE9403 (6GK5998-3GS00-2AC2)(CVE-2025-40582): Only use trusted SINEMA Remote Connect Servers
For more information see the associated Siemens security advisory SSA-327438 in HTML and CSAF.
  • May 15, 2025: Initial Republication of Siemens SSA-327438
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-135-18
