Siemens SICAM 8 Products
Multiple SICAM 8 products are affected by multiple vulnerabilities that could lead to denial of service, namely: - SICAM A8000 Device firmware - CPCI85 for CP-8031/CP-8050 - SICORE for CP-8010/CP-8012 - RTUM85 for CP-8010/CP-8012 - SICAM EGS Device firmware - CPCI85 - SICAM S8000 - SICORE - RTUM85 Siemens has released new versions for the affected products and recommends to update to the latest versions.
The following versions of Siemens SICAM 8 Products are affected:
  • CPCI85 Central Processing/Communication vers:intdot/<26.10 (CVE-2026-27663, CVE-2026-27664)
  • RTUM85 RTU Base vers:intdot/<26.10 (CVE-2026-27663)
  • SICORE Base system vers:intdot/<26.10.0 (CVE-2026-27664)
v3 7.5 Siemens Siemens SICAM 8 Products Allocation of Resources Without Limits or Throttling, Out-of-bounds Write
CVE-2026-27663
The affected application contains denial-of-service (DoS) vulnerability. The remote operation mode is susceptible to a resource exhaustion condition when subjected to a high volume of requests. Sending multiple requests can exhaust resources, preventing parameterization and requiring a reset or reboot to restore functionality.
CPCI85 Central Processing/Communication, RTUM85 RTU Base
Update to V26.10 or later version The firmware RTUM85 V26.10 is present within “CP-8010/CP-8012 Package” V26.10 https://support.industry.siemens.com/cs/ww/en/view/109972894/ and also within “SICAM S8000 Package” V26.10 https://support.industry.siemens.com/cs/document/109818240
Update to V26.10 or later version The firmware CPCI85 V26.10 is present within “CP-8031/CP-8050 Package” V26.10 https://support.industry.siemens.com/cs/ww/en/view/109804985/ and also within “SICAM EGS Package” V26.10 https://support.industry.siemens.com/cs/document/109972536/
3.1 6.5 MEDIUM CVSS:3.1/AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H
CVE-2026-27664
The affected application contains an out-of-bounds write vulnerability while parsing specially crafted XML inputs. This could allow an unauthenticated attacker to exploit this issue by sending a malicious XML request, which may cause the service to crash, resulting in a denial-of-service condition.
CPCI85 Central Processing/Communication, SICORE Base system
Update to V26.10.0 or later version The firmware SICORE V26.10.0 is present within “CP-8010/CP-8012 Package” V26.10 https://support.industry.siemens.com/cs/ww/en/view/109972894/ and also within “SICAM S8000 Package” V26.10 https://support.industry.siemens.com/cs/document/109818240
  • T. Weber, S. Dietz, D. Blagojevic, and F. Koroknai of CyberDanube coordinated disclosure of CVE-2026-27663
  • S. Dietz of CyberDanube and VERBUND Digital Power coordinated disclosure of CVE-2026-27664
  • S. Dietz of Siemens ProductCERT reported these vulnerabilities to CISA.
Operators of critical power systems (e.g. TSOs or DSOs) worldwide are usually required by regulations to build resilience into the power grids by applying multi-level redundant secondary protection schemes. It is therefore recommended that the operators check whether appropriate resilient protection measures are in place. The risk of cyber incidents impacting the grid's reliability can thus be minimized by virtue of the grid design. Siemens strongly recommends applying the provided security updates using the corresponding tooling and documented procedures made available with the product. If supported by the product, an automated means to apply the security updates across multiple product instances may be used. Siemens strongly recommends prior validation of any security update before being applied, and supervision by trained staff of the update process in the target environment. As a general security measure Siemens strongly recommends to protect network access with appropriate mechanisms (e.g. firewalls, segmentation, VPN). It is advised to configure the environment according to our operational guidelines in order to run the devices in a protected IT environment. Recommended security guidelines can be found at: https://www.siemens.com/gridsecurity
This ICSA is a verbatim republication of Siemens ProductCERT SSA-246443 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-03-26
2026-03-26 1 Publication Date
2026-04-02 2 Initial CISA Republication of Siemens ProductCERT SSA-246443 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-092-01
