- CVSS v4 7.1
- Vendor: Siemens
- Equipment: SIMATIC CN 4100
- Vulnerability: Improper Input Validation
Successful exploitation of this vulnerability could allow an attacker to cause a denial-of-service condition.
- SIMATIC CN 4100: All versions prior to V4.0
The affected application allows to control the device by storing arbitrary files in the SFTP folder of the device. This could allow an attacker to cause a denial-of-service condition.
CVE-2025-40593 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-40593. A base score of 7.1 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
Michael Klassen and Martin Floeck from BASF Security Team reported this vulnerability to Siemens.
- SIMATIC CN 4100: Update to V4.0 or later version
For more information see the associated Siemens security advisory SSA-626991 in HTML and CSAF.
- July 10, 2025: Initial Republication of Siemens SSA-626991
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-191-04
