Siemens Simcenter Femap and Nastran is affected by multiple file parsing vulnerabilities that could be triggered when the application reads files in NDB and XDB formats. If a user is tricked to open a malicious file with any of the affected products, this could lead the application to crash or potentially lead to arbitrary code execution. Siemens has released new versions for the affected products and recommends to update to the latest versions.
The following versions of Siemens Simcenter Femap and Nastran are affected:
- Simcenter Femap vers:intdot/<2512 (CVE-2026-23715, CVE-2026-23716, CVE-2026-23717, CVE-2026-23718, CVE-2026-23719, CVE-2026-23720)
- Simcenter Nastran vers:intdot/<2512 (CVE-2026-23715, CVE-2026-23716, CVE-2026-23717, CVE-2026-23718, CVE-2026-23719, CVE-2026-23720)
| v3 7.8 | Siemens | Siemens Simcenter Femap and Nastran | Out-of-bounds Write, Out-of-bounds Read, Heap-based Buffer Overflow |
CVE-2026-23715
The affected applications contains an out of bounds write vulnerability while parsing specially crafted XDB files. This could allow an attacker to execute code in the context of the current process.
Simcenter Femap, Simcenter Nastran
Do not open untrusted XDB files in affected applications
Update to V2512 or later version
https://support.sw.siemens.com/product/275652363/
https://support.sw.siemens.com/product/289054037/
| 3.1 | 7.8 | HIGH | CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H |
CVE-2026-23716
The affected applications contains an out of bounds read vulnerability while parsing specially crafted XDB files. This could allow an attacker to execute code in the context of the current process.
CVE-2026-23717
CVE-2026-23718
The affected applications contains an out of bounds read vulnerability while parsing specially crafted NDB files. This could allow an attacker to execute code in the context of the current process.
CVE-2026-23719
The affected application is vulnerable to heap-based buffer overflow while parsing specially crafted NDB files. This could allow an attacker to execute code in the context of the current process.
Do not open untrusted NDB files in affected applications
Relevant CWE: CWE-122 Heap-based Buffer Overflow
CVE-2026-23720
- Siemens ProductCERT reported these vulnerabilities to CISA.
- Michael Heinzl reported these vulnerabilities Siemens.
This ICSA is a verbatim republication of Siemens ProductCERT SSA-965753 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
| 2026-02-10 | 1 | Publication Date |
| 2026-02-17 | 2 | Initial CISA Republication of Siemens ProductCERT SSA-965753 advisory |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-048-01
