Siemens Simcenter Femap
Simcenter Femap is affected by heap based buffer overflow vulnerability in Datakit library that could be triggered when the application reads files in IPT format. If a user is tricked to open a malicious file with the affected application, an attacker could leverage the vulnerability to perform remote code execution in the context of the current process. Siemens has released a new version for Simcenter Femap and recommends to update to the latest version.
The following versions of Siemens Simcenter Femap are affected:
  • Simcenter Femap vers:intdot/<2512.0003
v3 7.8 Siemens Siemens Simcenter Femap Heap-based Buffer Overflow
CVE-2025-12659
The affected applications contains a memory corruption vulnerability while parsing specially crafted IPT files. This could allow an attacker to execute code in the context of the current process. (ZDI-CAN-27349, ZDI-CAN-27389)
Simcenter Femap
Update to V2512.0003 or later version
https://support.sw.siemens.com/product/275652363/
Relevant CWE: CWE-122 Heap-based Buffer Overflow
  • TrendAI Zero Day Initiative reported this vulnerability.
This ICSA is a verbatim republication of Siemens ProductCERT SSA-870926 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-05-12
2026-05-12 1 Publication Date
2026-05-14 2 Initial CISA Republication of Siemens ProductCERT SSA-870926 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-134-05
