- CVSS v4 6.8
- ATTENTION: Low Attack Complexity
- Vendor: Siemens
- Equipment: SIMOTION SCOUT, SIMOTION SCOUT TIA, SINAMICS STARTER
- Vulnerability: Improper Restriction of XML External Entity Reference
Successful exploitation of this vulnerability could allow an attacker to access arbitrary application files.
- SIMOTION SCOUT TIA V5.4: All versions
- SINAMICS STARTER V5.6: All versions
- SINAMICS STARTER V5.7: All versions
- SIMOTION SCOUT TIA V5.5: All versions
- SIMOTION SCOUT TIA V5.6: Versions prior to V5.6 SP1 HF7
- SIMOTION SCOUT TIA V5.7: Versions prior to V5.7 SP1 HF1
- SIMOTION SCOUT V5.4: All versions
- SIMOTION SCOUT V5.5: All versions
- SIMOTION SCOUT V5.6: Versions prior to V5.6 SP1 HF7
- SIMOTION SCOUT V5.7: Versions prior to V5.7 SP1 HF1
- SINAMICS STARTER V5.5: All versions
3.2.1 IMPROPER RESTRICTION OF XML EXTERNAL ENTITY REFERENCE CWE-611
The affected application contains a XML External Entity Injection (XXE) vulnerability while parsing specially crafted XML files. This could allow an attacker to read arbitrary files in the system.
CVE-2025-40584 has been assigned to this vulnerability. A CVSS v3.1 base score of 5.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-40584. A base score of 6.8 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:N/UI:P/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
Michael Heinzl reported this vulnerability to Siemens.
- Do not open untrusted XML files in affected applications
- SIMOTION SCOUT V5.4, SIMOTION SCOUT V5.5, SINAMICS STARTER V5.5, SINAMICS STARTER V5.6: Currently no fix is planned
- SIMOTION SCOUT TIA V5.4, SIMOTION SCOUT TIA V5.5, SINAMICS STARTER V5.7: Currently no fix is available
- SIMOTION SCOUT TIA V5.6, SIMOTION SCOUT V5.6: Update to V5.6 SP1 HF7 or later version
- SIMOTION SCOUT TIA V5.7, SIMOTION SCOUT V5.7: Update to V5.7 SP1 HF1 or later version
For more information see the associated Siemens security advisory SSA-186293 in HTML and CSAF.
- August 14, 2025: Initial Republication of Siemens SSA-186293
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-226-18
