Siemens SINEC NMS
SINEC NMS before V4.0 SP3 contains an Authorization Bypass vulnerability that could allow an attacker to bypass authorization checks, leading to the ability to reset the password of any arbitrary user account. Siemens has released a new version for SINEC NMS and recommends to update to the latest version.
The following versions of Siemens SINEC NMS are affected:
  • SINEC NMS
v3 8.8 Siemens Siemens SINEC NMS Authorization Bypass Through User-Controlled Key
CVE-2026-25654
Affected products do not properly validate user authorization when processing password reset requests. This could allow an authenticated remote attacker to bypass authorization checks, leading to the ability to reset the password of any arbitrary user account.
Siemens SINEC NMS
SINEC NMS
Limit network access to trusted users and systems only
Update to V4.0 SP3 or later version
https://support.industry.siemens.com/cs/ww/en/view/110000760/
Relevant CWE: CWE-639 Authorization Bypass Through User-Controlled Key
This ICSA is a verbatim republication of Siemens ProductCERT SSA-605717 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-04-14
2026-04-14 1 Publication Date
2026-04-21 2 Initial CISA Republication of Siemens ProductCERT SSA-605717 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-111-09
