Siemens SINEC Security Monitor
SINEC Security Monitor before V4.10.0 contains multiple vulnerabilities. Siemens has released a new version for SINEC Security Monitor and recommends to update to the latest version.
The following versions of Siemens SINEC Security Monitor are affected:
  • SINEC Security Monitor (CVE-2025-40830, CVE-2025-40831)
v3 6.7 Siemens Siemens SINEC Security Monitor Improper Authorization, Improper Input Validation
CVE-2025-40830
The affected application does not have proper authorization checks for the file_transfer feature in ssmctl-client command. This could allow an authenticated, lowly privileged local attacker to read or write to any file on server or sensor.
Update to V4.10.0 or later version
Relevant CWE: CWE-285 Improper Authorization
3.1 6.7 MEDIUM CVSS:3.1/AV:L/AC:L/PR:H/UI:N/S:U/C:H/I:H/A:H
CVE-2025-40831
The affected application lacks input validation of date parameter in report generation functionality. This could allow an authenticated, lowly privileged attacker to cause denial of service condition of the report functionality.
Relevant CWE: CWE-20 Improper Input Validation
3.1 6.5 MEDIUM CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:N/A:H
  • Siemens ProductCERT reported these vulnerabilities to CISA.
This ICSA is a verbatim republication of Siemens ProductCERT SSA-882673 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2025-12-09
2025-12-09 1 Publication Date
2026-01-14 2 Initial Republication of Siemens ProductCERT SSA-882673 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-015-06
