- CVSS v3 4.3
- Vendor: Siemens
- Equipment: SINEMA Remote Connect Server
- Vulnerabilities: Incorrect Permission Assignment for Critical Resource, Incorrect Authorization
Successful exploitation of these vulnerabilities could allow an authenticated attacker to impersonate the server potentially enabling man-in-the-middle, traffic decryption, or unauthorized access to services that trust these certificates.
- SINEMA Remote Connect Server: All versions prior to V3.2 SP4
3.2.1 INCORRECT PERMISSION ASSIGNMENT FOR CRITICAL RESOURCE CWE-732
Affected applications contain private SSL/TLS keys on the server that are not properly protected allowing any user with server access to read these keys. This could allow an authenticated attacker to impersonate the server potentially enabling man-in-the-middle, traffic decryption or unauthorized access to services that trust these certificates.
CVE-2025-40818 has been assigned to this vulnerability. A CVSS v3.1 base score of 3.3 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:L/I:N/A:N).
3.2.2 INCORRECT AUTHORIZATION CWE-863
Affected applications do not properly validate license restrictions against the database, allowing direct modification of the system_ticketinfo table to bypass license limitations without proper enforcement checks. This could allow an attacker with database access to circumvent licensing restrictions by directly modifying database values and potentially enabling unauthorized use beyond the permitted scope.
CVE-2025-40819 has been assigned to this vulnerability. A CVSS v3.1 base score of 4.3 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:L/A:N).
Siemens ProductCERT reported these vulnerabilities to CISA.
- SINEMA Remote Connect Server: Update to V3.2 SP4 or later version
For more information see the associated Siemens security advisory SSA-626856 in HTML and CSAF.
- December 11, 2025: Initial Republication of Siemens ProductCERT SSA-626856
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-345-06
