Siemens SiPass
  • CVSS v4 8.2
  • Equipment: SiPass
  • Vulnerability: Improper Verification of Cryptographic Signature
Successful exploitation of this vulnerability could allow an attacker to upload a maliciously modified firmware onto the device.
  • Siemens SiPass integrated AC5102 (ACC-G2): All versions
  • Siemens SiPass integrated ACC-AP: All versions
3.2.1 IMPROPER VERIFICATION OF CRYPTOGRAPHIC SIGNATURE CWE-347
Affected devices do not properly check the integrity of firmware updates. This could allow a local attacker to upload a maliciously modified firmware onto the device. In a second scenario, a remote attacker who is able to intercept the transfer of a valid firmware from the server to the device could modify the firmware "on the fly".
CVE-2022-31807 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.2 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2022-31807. A base score of 8.2 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:P/PR:N/UI:N/VC:N/VI:H/VA:N/SC:N/SI:N/SA:N).
  • All affected products: Enable TLS for communication between servers and affected devices; this mitigates the risk of on-path attackers that intercept and modify the firmware during transmission
  • All affected products: Currently no fix is available
For more information see the associated Siemens security advisory SSA-367714 in HTML and CSAF.
  • May 29, 2025: Initial Republishing of Siemens SSA-367714
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-148-01
