Siemens SIPROTEC 5
As of January 10, 2023, CISA will no longer be updating ICS security advisories for Siemens product vulnerabilities beyond the initial advisory. For the most up-to-date information on vulnerabilities in this advisory, see Siemens' ProductCERT Security Advisories (CERT Services | Services | Siemens Global).
  • CVSS v4 6.0
  • Equipment: SIPROTEC 5
  • Vulnerability: Use of GET Request Method With Sensitive Query Strings
Successful exploitation of this vulnerability could allow an attacker to retrieve sensitive session data from browser history, logs, or other storage mechanisms, potentially leading to unauthorized access.
  • SIPROTEC 5 6MD84 (CP300): All versions
  • SIPROTEC 5 7SA86 (CP300): All versions
  • SIPROTEC 5 7SA87 (CP300): All versions
  • SIPROTEC 5 7SD82 (CP100): All versions
  • SIPROTEC 5 7SD82 (CP150): All versions
  • SIPROTEC 5 7SD86 (CP300): All versions
  • SIPROTEC 5 7SD87 (CP300): All versions
  • SIPROTEC 5 7SJ81 (CP100): All versions
  • SIPROTEC 5 7SJ81 (CP150): All versions
  • SIPROTEC 5 7SJ82 (CP100): All versions
  • SIPROTEC 5 7SJ82 (CP150): All versions
  • SIPROTEC 5 6MD85 (CP300): All versions
  • SIPROTEC 5 7SJ85 (CP300): All versions
  • SIPROTEC 5 7SJ86 (CP300): All versions
  • SIPROTEC 5 7SK82 (CP100): All versions
  • SIPROTEC 5 7SK82 (CP150): All versions
  • SIPROTEC 5 7SK85 (CP300): All versions
  • SIPROTEC 5 7SL82 (CP100): All versions
  • SIPROTEC 5 7SL82 (CP150): All versions
  • SIPROTEC 5 7SL86 (CP300): All versions
  • SIPROTEC 5 7SL87 (CP300): All versions
  • SIPROTEC 5 7SS85 (CP300): All versions
  • SIPROTEC 5 6MD86 (CP300): All versions
  • SIPROTEC 5 7ST85 (CP300): All versions
  • SIPROTEC 5 7ST86 (CP300): All versions
  • SIPROTEC 5 7SX82 (CP150): All versions
  • SIPROTEC 5 7SX85 (CP300): All versions
  • SIPROTEC 5 7SY82 (CP150): All versions
  • SIPROTEC 5 7UM85 (CP300): All versions
  • SIPROTEC 5 7UT82 (CP100): All versions
  • SIPROTEC 5 7UT82 (CP150): All versions
  • SIPROTEC 5 7UT85 (CP300): All versions
  • SIPROTEC 5 7UT86 (CP300): All versions
  • SIPROTEC 5 6MD89 (CP300): All versions
  • SIPROTEC 5 7UT87 (CP300): All versions
  • SIPROTEC 5 7VE85 (CP300): All versions
  • SIPROTEC 5 7VK87 (CP300): All versions
  • SIPROTEC 5 7VU85 (CP300): All versions
  • SIPROTEC 5 Compact 7SX800 (CP050): All versions
  • SIPROTEC 5 6MD89 (CP300) V9.6: All versions
  • SIPROTEC 5 6MU85 (CP300): All versions
  • SIPROTEC 5 7KE85 (CP300): All versions
  • SIPROTEC 5 7SA82 (CP100): All versions
  • SIPROTEC 5 7SA82 (CP150): All versions
3.2.1 USE OF GET REQUEST METHOD WITH SENSITIVE QUERY STRINGS CWE-598
The affected devices include session identifiers in URL requests for certain functionalities. This could allow an attacker to retrieve sensitive session data from browser history, logs, or other storage mechanisms, potentially leading to unauthorized access.
CVE-2025-40742 has been assigned to this vulnerability. A CVSS v3 base score of 5.3 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:H/PR:N/UI:R/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-40742. A base score of 6.0 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:H/AT:N/PR:N/UI:P/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Energy, Critical Manufacturing
  • COMPANY HEADQUARTERS LOCATION: Siemens
Nozomi Networks reported this vulnerability to Siemens.
Siemens is preparing fixed versions and recommends countermeasures for products where fixes are unavailable or not yet available.
Operators of critical power systems (e.g., TSOs or DSOs) worldwide are typically required by regulations to build resilience into the power grids by applying multi-level redundant secondary protection schemes. Therefore, operators should check whether appropriate resilient protection measures are in place. The risk of cyber incidents affecting the grid's reliability can thus be minimized by the grid design. Siemens strongly recommends applying the provided security updates using the corresponding tools and documented procedures that accompany the product. If the product supports this capability, an automated method can be used to apply the security updates across multiple product instances. Siemens strongly recommends validating any security update before it is applied and ensuring that trained staff supervise the update process in the target environment. As a general security measure, Siemens strongly recommends protecting network access with appropriate security mechanisms (e.g., firewalls, segmentation, VPN). It is advised that the environment be configured according to Siemens' operational guidelines to operate the devices in a protected IT environment.
For more information see the associated Siemens security advisory SSA-904646 in HTML and CSAF.
  • July 10, 2025: Initial Republication of Siemens SSA-904646
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-191-06
