- CVSS v4 9.1
- Vendor: Siemens
- Equipment: SIPROTEC and SICAM
- Vulnerability: Improper Enforcement of Message Integrity During Transmission in a Communication Channel
Successful exploitation of this vulnerability could cause the network access server to grant the attacker access to the network with the attacker's desired authorization and without the need of knowing or guessing legitimate access credentials.
Siemens reports the following products using the RADIUS protocol are affected:
- CPC80 Central Processing/Communication: All versions
- CPCI85 Central Processing/Communication: All versions
- POWER METER SICAM Q100 family: All versions prior to V2.70
- POWER METER SICAM Q200 family: All versions
- Powerlink IP: All versions
- SICAM GridPass: All versions prior to V2.50
- SICORE Base system: All versions
- SIPROTEC 5 Compact 7SX800 (CP050): All versions
- SIPROTEC 5 7SA82 (CP100): Versions V7.80 and after
- SIPROTEC 5 7SD82 (CP100): Versions V7.80 and after
- SIPROTEC 5 7SJ81 (CP100): Versions V7.80 and after
- SIPROTEC 5 7SJ82 (CP100): Versions V7.80 and after
- SIPROTEC 5 7SK82 (CP100): Versions V7.80 and after
- SIPROTEC 5 7SL82 (CP100): Versions V7.80 and after
- SIPROTEC 5 7UT82 (CP100): Versions V7.80 and after
- SIPROTEC 5 7SA82 (CP150): All versions
- SIPROTEC 5 7SD82 (CP150): All versions
- SIPROTEC 5 7SJ81 (CP150): All versions
- SIPROTEC 5 7SJ82 (CP150): All versions
- SIPROTEC 5 7SK82 (CP150): All versions
- SIPROTEC 5 7SL82 (CP150): All versions
- SIPROTEC 5 7SX82 (CP150): All versions
- SIPROTEC 5 7SY82 (CP150): All versions
- SIPROTEC 5 7UT82 (CP150): All versions
- SIPROTEC 5 6MD84 (CP300): All versions
- SIPROTEC 5 6MD85 (CP300): Versions V7.80 and after
- SIPROTEC 5 6MD86 (CP300): Versions V7.80 and after
- SIPROTEC 5 6MD89 (CP300): Versions V7.80 and after
- SIPROTEC 5 6MD89 (CP300) V9.6: Versions prior to V9.68
- SIPROTEC 5 6MU85 (CP300): All versions
- SIPROTEC 5 7KE85 (CP300): Versions V7.80 and after
- SIPROTEC 5 7SA86 (CP300): Versions V7.80 and after
- SIPROTEC 5 7SA87 (CP300): Versions V7.80 and after
- SIPROTEC 5 7SD86 (CP300): Versions V7.80 and after
- SIPROTEC 5 7SD87 (CP300): Versions V7.80 and after
- SIPROTEC 5 7SJ85 (CP300): Versions V7.80 and after
- SIPROTEC 5 7SJ86 (CP300): Versions V7.80 and after
- SIPROTEC 5 7SK85 (CP300): Versions V7.80 and after
- SIPROTEC 5 7SL86 (CP300): Versions V7.80 and after
- SIPROTEC 5 7SL87 (CP300): Versions V7.80 and after
- SIPROTEC 5 7SS85 (CP300): Versions V7.80 and after
- SIPROTEC 5 7ST85 (CP300): Versions prior to V9.68
- SIPROTEC 5 7ST86 (CP300): Versions prior to V9.83
- SIPROTEC 5 7SX85 (CP300): All versions
- SIPROTEC 5 7UM85 (CP300): Versions V7.80 and after
- SIPROTEC 5 7UT85 (CP300): Versions V7.80 and after
- SIPROTEC 5 7UT86 (CP300): Versions V7.80 and after
- SIPROTEC 5 7UT87 (CP300): Versions V7.80 and after
- SIPROTEC 5 7VE85 (CP300): Versions V7.80 and after
- SIPROTEC 5 7VK87 (CP300): Versions V7.80 and after
- SIPROTEC 5 7VU85 (CP300): All versions
3.2.1 IMPROPER ENFORCEMENT OF MESSAGE INTEGRITY DURING TRANSMISSION IN A COMMUNICATION CHANNEL CWE-924
The RADIUS Protocol under RFC 2865 is susceptible to forgery attacks by a local attacker who can modify responses Access-Reject or Access-Accept using a chosen-prefix collision attack against MD5 Response Authenticator signature.
CVE-2024-3596 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.0 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2024-3596. A base score of 9.1 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:P/PR:N/UI:N/VC:N/VI:H/VA:N/SC:H/SI:H/SA:H).
Siemens has released new versions for several of the affected products and recommends updating to the latest versions and configuring the updated systems as follows. Siemens is preparing additional fix versions and recommends specific countermeasures for products where fixes are not yet available.
- POWER METER SICAM Q100 family: Update to V2.70 or a later version.
- SICAM GridPass: Update to V2.50 or a later version.
- SIPROTEC 5 6MD89 (CP300) V9.6, SIPROTEC 5 7ST85 (CP300): Update to V9.68 or a later version.
- SIPROTEC 5 7ST86 (CP300): Update to V9.83 or a later version.
- Restrict access to the networks where RADIUS messages are exchanged (e.g., send RADIUS traffic via management network or a dedicated VLAN).
- Configure the RADIUS server to require the presence of a Message-Authenticator attribute in all Access-Request packets from RADIUS client devices that support it.
For more information see the associated Siemens security advisory SSA-794185 in HTML and CSAF.
- May 15, 2025: Initial Republication of Siemens SSA-794185
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-135-05
