The Webhooks implementation of Siveillance Video Management Servers contains a vulnerability that could allow an authenticated remote attacker with read-only privileges to achieve full access to Webhooks API. Siemens has released new versions for the affected products and recommends to update to the latest versions.
The following versions of Siemens Siveillance Video Management Servers are affected:
- Siveillance Video V2023 R1: All versions < V23.1 HotfixRev18
- Siveillance Video V2023 R2: All versions < V23.2 HotfixRev18
- Siveillance Video V2023 R3: All versions < V23.3 HotfixRev23
- Siveillance Video V2024 R1: All versions < V24.1 HotfixRev14
- Siveillance Video V2025: All versions < V25.1 HotfixRev8
| v3 6.3 | Siemens | Siemens Siveillance Video Management Servers | Missing Authorization |
CVE-2025-0836
Missing Authorization vulnerability in Milestone Systems XProtect VMS allows users with read-only access to Management Server to have full read/write access to MIP Webhooks API.
Siveillance Video V2023 R1, Siveillance Video V2023 R2, Siveillance Video V2023 R3, Siveillance Video V2024 R1, Siveillance Video V2025
If, for any reason it is not possible to install the latest patch, we recommend auditing your role security settings and consider everyone with read-only access to the Management Server as having a full access to Webhooks configuration.
Update to V23.1 HotfixRev18 or later version
Update to V23.2 HotfixRev18 or later version
Update to V23.3 HotfixRev23 or later version
Update to V24.1 HotfixRev14 or later version
Update to V25.1 HotfixRev8 or later version
Relevant CWE: CWE-862 Missing Authorization
| 3.1 | 6.3 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:L/I:L/A:L |
- Milestone PSIRT reported this vulnerability to Siemens.
As a general security measure Siemens strongly recommends to protect network access to affected products with appropriate mechanisms. It is advised to follow recommended security practices in order to run the devices in a protected IT environment.
This ICSA is a verbatim republication of Siemens ProductCERT SSA-625934 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
| 2026-02-10 | 1 | Publication Date |
| 2026-02-12 | 2 | Initial CISA Republication of Siemens ProductCERT SSA-625934 advisory |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-043-07
