Siemens Software Center and Solid Edge
  • CVSS v4 8.5
  • Equipment: Software Center and Solid Edge
  • Vulnerability: Uncontrolled Search Path Element
Successful exploitation of this vulnerability could allow an attacker to execute arbitrary code via placing a crafted DLL file on the system.
The following versions of Siemens Software Center and Solid Edge are affected:
  • Siemens Software Center: All versions prior to 3.5
  • Solid Edge SE2025: All versions prior to V225.0 Update 10
3.2.1 UNCONTROLLED SEARCH PATH ELEMENT CWE-427
The affected application is vulnerable to DLL hijacking. This could allow an attacker to execute arbitrary code via placing a crafted DLL file on the system.
CVE-2025-40827 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-40827. A base score of 8.5 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:P/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Sahil Shah from National Forensic Sciences University reported this vulnerability to Siemens.
For more information see the associated Siemens security advisory SSA-365596 in HTML and CSAF.
  • November 13, 2025: Initial Republication of Siemens SSA-365596
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-317-17
