Siemens Solid Edge
Solid Edge SE2026 before Update 5 is affected by two file parsing vulnerabilities that could be triggered when the application reads specially crafted files in PAR format. This could allow an attacker to crash the application or execute arbitrary code. Siemens has released a new version for Solid Edge SE2026 and recommends to update to the latest version.
The following versions of Siemens Solid Edge are affected:
  • Solid Edge vers:intdot/<226.0.5
v3 7.8 Siemens Siemens Solid Edge Access of Uninitialized Pointer, Stack-based Buffer Overflow
CVE-2026-44411
The affected application is vulnerable to uninitialized pointer access while parsing specially crafted PAR files. An attacker could leverage this vulnerability to execute code in the context of the current process.
Siemens Solid Edge
Solid Edge
Update to V226.0 Update 5 or later version
https://support.sw.siemens.com/product/246738425/
Relevant CWE: CWE-824 Access of Uninitialized Pointer
CVE-2026-44412
The affected applications contain a stack based overflow vulnerability while parsing specially crafted PAR files. This could allow an attacker to execute code in the context of the current process.
Siemens Solid Edge
Solid Edge
  • Michael Heinzl reported these vulnerabilities.
This ICSA is a verbatim republication of Siemens ProductCERT SSA-921111 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Siemens ProductCERT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-05-12
2026-05-12 1 Publication Date
2026-05-13 2 Fixed error in title with the change from SE225 to SE226
2026-05-14 3 Initial CISA Republication of Siemens ProductCERT SSA-921111 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-134-03
