Siemens Tecnomatix Plant Simulation
  • CVSS v4 7.3
  • Equipment: Tecnomatix Plant Simulation
  • Vulnerability: Out-of-bounds Read
Successful exploitation of this vulnerability could allow an attacker to execute code in the context of the current process.
  • Tecnomatix Plant Simulation V2404: All versions prior to V2404.0013
3.2.1 OUT-OF-BOUNDS READ CWE-125
The affected applications contain an out-of-bounds read past the end of an allocated structure while parsing specially crafted WRL files. This could allow an attacker to execute code in the context of the current process.
CVE-2025-32454 has been assigned to this vulnerability. A CVSS v3 base score of 7.8 has been assigned; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-32454. A base score of 7.3 has been calculated; the CVSS vector string is (AV:L/AC:H/AT:N/PR:N/UI:P/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Michael Heinzl reported this vulnerability to Siemens. Siemens reported this vulnerability to CISA.
  • Tecnomatix Plant Simulation V2404: Do not open untrusted WRL files in affected applications
  • Tecnomatix Plant Simulation V2404: Update to V2404.0013 or later version
For more information see the associated Siemens security advisory SSA-486186 in HTML and CSAF.
  • June 12, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-162-01
