Successful exploitation of these vulnerabilities could allow an attacker to execute arbitrary code, cause a denial-of-service, or configuration information may be altered without authentication.
The following versions of Silex Technology SD-330AC and AMC Manager are affected:
- SD-330AC <=1.42 (CVE-2026-32955, CVE-2026-32956, CVE-2026-32957, CVE-2026-32958, CVE-2015-5621, CVE-2026-32959, CVE-2026-32960, CVE-2026-32961, CVE-2026-32962, CVE-2024-24487, CVE-2026-32963, CVE-2026-32964, CVE-2026-32965)
- AMC Manager <=5.0.2 (CVE-2026-32955, CVE-2026-32956, CVE-2026-32957, CVE-2026-32958, CVE-2015-5621, CVE-2026-32959, CVE-2026-32960, CVE-2026-32961, CVE-2026-32962, CVE-2024-24487, CVE-2026-32963, CVE-2026-32964, CVE-2026-32965)
| v3 9.8 | Silex Technology | Silex Technology SD-330AC and AMC Manager | Stack-based Buffer Overflow, Heap-based Buffer Overflow, Missing Authentication for Critical Function, Use of Hard-coded Cryptographic Key, Dependency on Vulnerable Third-Party Component, Use of a Broken or Risky Cryptographic Algorithm, Sensitive Information in Resource Not Removed Before Reuse, Incorrect Privilege Assignment, Improper Neutralization of Input During Web Page Generation ('Cross-site Scripting'), Improper Neutralization of CRLF Sequences ('CRLF Injection'), Initialization of a Resource with an Insecure Default |
- Critical Infrastructure Sectors: Information Technology
- Company Headquarters Location: Japan
CVE-2026-32955
A Stack-based Buffer Overflow vulnerability in Silex Technology SD-330AC and AMC Manager could allow an attacker to execute arbitrary code on the device.
Silex Technology
Silex Technology SD-330AC: <=1.42, Silex Technology AMC Manager: <=5.0.2
The developer has released the following versions to address this vulnerability: SD-330AC firmware Ver 1.50 or later
AMC Manager Ver.5.1.0 or later
CVE-2026-32955, CVE-2026-32956, CVE-2026-32957, and CVE-2026-32963: Disable HTTP/HTTPS service.
For more information, see Silex Technology's security advisory in English (https://www.silex.jp/support/security-advisories/en/2026-001) or in Japanese (https://www.silex.jp/support/security-advisories/2026-001).
For more information, see JPCERT/CC vulnerability notes in English (https://jvn.jp/en/vu/JVNVU94271449/) or in Japanese (https://jvn.jp/vu/JVNVU94271449/).
| 3.1 | 8.8 | HIGH | CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H |
CVE-2026-32956
A Heap-based Buffer Overflow vulnerability in Silex Technology SD-330AC and AMC Manager could allow an attacker to execute arbitrary code on the device.
Silex Technology
Relevant CWE: CWE-122 Heap-based Buffer Overflow
CVE-2026-32957
A Missing Authentication for Critical Function vulnerability in Silex Technology SD-330AC and AMC Manager could allow uploads of arbitrary files to the device without authentication.
Silex Technology
| 3.1 | 5.3 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:L/A:N |
CVE-2026-32958
A Use of Hard-coded Cryptographic Key vulnerability in Silex Technology SD-330AC and AMC Manager could cause an administrative user to be directed to apply a fake firmware update.
Silex Technology
CVE-2026-32958 and CVE-2026-32965: Set a password for the settings web interface.
Relevant CWE: CWE-321 Use of Hard-coded Cryptographic Key
| 3.1 | 6.5 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:R/S:U/C:N/I:H/A:N |
CVE-2015-5621
The snmp_pdu_parse function in snmp_api.c in net-snmp 5.7.2 and earlier does not remove the varBind variable in a netsnmp_variable_list item when parsing of the SNMP PDU fails, which allows remote attackers to cause a denial of service (crash).
Silex Technology
CVE-2015-5621: Disable SNMP service.
Relevant CWE: CWE-1395 Dependency on Vulnerable Third-Party Component
CVE-2026-32959
A Use of a Broken or Risky Cryptographic Algorithm vulnerability in Silex Technology SD-330AC and AMC Manager could allow an attacker to retrieve information via a man-in-the-middle attack.
Silex Technology
Relevant CWE: CWE-327 Use of a Broken or Risky Cryptographic Algorithm
| 3.1 | 5.9 | MEDIUM | CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:H/I:N/A:N |
CVE-2026-32960
A Sensitive Information in Resource Not Removed Before Reuse vulnerability in Silex Technology SD-330AC and AMC Manager could allow an attacker to send specially crafted packets that may allow the attacker to login to the device.
Silex Technology
Relevant CWE: CWE-226 Sensitive Information in Resource Not Removed Before Reuse
CVE-2026-32961
A Heap-based Buffer Overflow vulnerability in Silex Technology SD-330AC and AMC Manager could allow an attacker to send specially crafted packets that may cause a temporary denial-of-service (DoS) condition.
Silex Technology
| 3.1 | 5.3 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L |
CVE-2026-32962
A Missing Authentication for Critical Function vulnerability in Silex Technology SD-330AC and AMC Manager could allow an attacker to alter the device configuration without authentication.
Silex Technology
CVE-2024-24487
An issue discovered in Silex Technology DS-600 Firmware v.1.4.1 allows a remote attacker to cause a denial of service via crafted UDP packets using the EXEC REBOOT SYSTEM command.
Silex Technology
Relevant CWE: CWE-266 Incorrect Privilege Assignment
| 3.1 | 6.8 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:L/UI:R/S:U/C:L/I:L/A:H |
CVE-2026-32963
An Improper Neutralization of Input During Web Page Generation ('Cross-site Scripting') vulnerability in Silex Technology SD-330AC and AMC Manager could allow an attacker to trick a user into accessing a special web page and execute arbitrary script on the user's browser.
Silex Technology
| 3.1 | 6.1 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:R/S:C/C:L/I:L/A:N |
CVE-2026-32964
An Improper Neutralization of CRLF Sequences ('CRLF Injection') vulnerability in Silex Technology SD-330AC and AMC Manager could allow an attacker to inject arbitrary entries into the system configuration.
Silex Technology
Relevant CWE: CWE-93 Improper Neutralization of CRLF Sequences ('CRLF Injection')
| 3.1 | 6.5 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:L/A:L |
CVE-2026-32965
An Initialization of a Resource with an Insecure Default vulnerability in Silex Technology SD-330AC and AMC Manager could allow an attacker using the factory default configuration to configure the device using the null string password.
Silex Technology
Relevant CWE: CWE-1188 Initialization of a Resource with an Insecure Default
| 3.1 | 7.5 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:N |
- Francesco La Spina of Forescout Technologies reported these vulnerabilities to CISA
- Initial Release Date: 2026-04-21
| 2026-04-21 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-111-10
