- CVSS v4 8.3
- Vendor: SolisCloud
- Equipment: Monitoring Platform (Cloud API & Device Control API)
- Vulnerability: Authorization Bypass Through User-Controlled Key
Successful exploitation of this vulnerability could allow an attacker to access sensitive information by manipulating API requests.
The following versions of SolisCloud Monitoring Platform are affected:
- Monitoring Platform (Cloud API & Device Control API): API v1 and API v2
3.2.1 AUTHORIZATION BYPASS THROUGH USER-CONTROLLED KEY CWE-639
The SolisCloud API suffers from a Broken Access Control vulnerability, specifically an Insecure Direct Object Reference (IDOR), where any authenticated user can access detailed data of any plant by altering the plant_id in the request.
CVE-2025-13932 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.7 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:C/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-13932. A base score of 8.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:N/VA:N/SC:H/SI:N/SA:N).
- CRITICAL INFRASTRUCTURE SECTORS: Energy
- COMPANY HEADQUARTERS LOCATION: China
James Gallagher (@5G) reported this vulnerability to CISA.
SolisCloud has not responded to requests to work with CISA to mitigate this vulnerability. Users of affected versions of SolisCloud Monitoring Platform are invited to contact SolisCloud customer support for additional information.
- December 04, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-338-06
