So not sure if anyone is interested but i saw a video recently on RSA encryption…
Easiest explanation: (actual calculations aren’t correct)
Multiply 2 Prime Numbers:
#1- 84584534965946536564365 (Private Key)
#2- 24145453656546456778656 (Private Key)
Semi Prime Number:
# = 54584375843948594823598439589438593 (Public Key)
In short a hacker would see the Public Key/Semi Prime Number, and would have to find the combinations that would equal your 2 original Private keys exactly… With a Semi Prime number that large it would take a very long time to find the original Prime Numbers.
Hope this helps ![]()
