- CVSS v4 8.7
- ATTENTION: Exploitable remotely
- Vendor: Westermo Network Technologies
- Equipment: WeOS 5
- Vulnerability: Improper Neutralization of Special Elements used in an OS Command ('OS Command Injection')
Successful exploitation of this vulnerability could allow an attacker with administrative permissions to execute commands that would typically be inaccessible. This could allow the execution of commands with privileges beyond those normally granted to the attacker.
Westermo reports following versions of WeOS 5, an industrial network operating system, are affected:
- WeOS 5: Versions 5.24 and later
3.2.1 IMPROPER NEAUTRALIZATION OF SPECIAL ELEMENTS USED IN AN OS COMMAND ('OS COMMAND INJECTION') CWE-78
Westermo has identified a vulnerability in WeOS 5 that could potentially be used to inject OS commands due to unsafe handling of media definitions.
CVE-2025-46418 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.6 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:H/PR:H/UI:R/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-46418. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:H/AT:N/PR:H/UI:A/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
- CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Critical Manufacturing, Energy, Water and Wastewater Systems
- COMPANY HEADQUARTERS LOCATION: Sweden
Westermo reported this vulnerability to CISA.
Westermo recommends the following mitigations which do not require a software update:
- Limit administration account access to trusted parties.
- Use best practices for passwords related to administration accounts.
For more information refer to Westermo's security advisory Westermo-25-07.
- When remote access is required, use more secure methods, such as virtual private networks (VPNs), recognizing VPNs may have vulnerabilities and should be updated to the most current version available. Also recognize VPN is only as secure as the connected devices.
- September 18, 2025 - Initial Republication of Westermo's security advisory Westermo-25-07
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-261-01
