So what tech type projects are you all up to? Personally (if you can’t tell from the YouTube videos) I’m working on setting up my Windows lab (yes, still).
P.S. Its a lot harder to setup a lab when you are recording everything ![]()
-I’ve start making a nagios installation/configuration tutorial/keynote and i’m starting to do the same with cactis… I was wondering if i make a video about it or just post the instruction here… or both
-I was thinking to put a server in the garage and i was wondering if in summer the temperature was getting too hot, so i start to check to make a raspberry pi remote temperature, to use with nagios
-I also found this week a video of a guy that was doing backup on a server, but he made a script to wake the computer with wake on lan and do the backup and then shutdown the backup server, so the drive don’t run 7/7 24/24, which i think is a cool idea
@Connor did you change de logo ? ![]()
remote temperature already premade are like 300 $, you can make one for 100$…
