Yokogawa CENTUM VP
Successful exploitation of this vulnerability could allow an attacker to login as the PROG user and modify permissions.
The following versions of Yokogawa CENTUM VP are affected:
  • CENTUM VP >=R5.01.00|
  • CENTUM VP >=R6.01.00|
  • CENTUM VP vR7.01.00 (CVE-2025-7741)
v3 4 Yokogawa Yokogawa CENTUM VP Use of Hard-coded Password
  • Critical Infrastructure Sectors: Critical Manufacturing, Energy, Food and Agriculture
  • Company Headquarters Location: Japan
CVE-2025-7741
Affected products contain a hardcoded password for the user account (PROG) used for CENTUM Authentication Mode within the system. Under the following conditions, there is a risk that an attacker could log in as the PROG user. The default permission for the PROG users is S1 permission (equivalent to OFFUSER). Therefore, for properly permission-controlled targets of operation and monitoring, even if an attacker logs in as the PROG user, the risk of critical operations or configuration changes being performed is considered low. If the PROG user's permissions have been changed for any reason, there is a risk that operations or configuration changes may be performed under the modified permissions. Additionally, exploiting this vulnerability requires an attacker to already have access to the HIS screen controls.
Yokogawa CENTUM VP
Yokogawa
Yokogawa CENTUM VP: >=R5.01.00|=R6.01.00|
Yokogawa recommends users applying the following mitigations to affected versions:
CENTUM VP R5.01.00 to R5.04.20: Change the user authentication mode to Windows Authentication Mode.
CENTUM VP R6.01.00 to R6.12.00: Change the user authentication mode to Windows Authentication Mode.
CENTUM VP R7.01.00: Apply patch software R7.01.10.
NOTE:Changing to Windows Authentication Mode requires engineering work. If users wish to make this change, please contact Yokogawa directly https://contact.yokogawa.com/cs/gw?c-id=000498.
For more information and details on implementing these mitigations, users should see the Yokogawa advisory YSAR-26-0003 at https://web-material3.yokogawa.com/1/39281/files/YSAR-26-0003-E.pdf
Relevant CWE: CWE-259 Use of Hard-coded Password
3.1 4 MEDIUM CVSS:3.1/AV:L/AC:H/PR:N/UI:N/S:U/C:L/I:L/A:N
  • Yokogawa reported this vulnerability to CISA
No known public exploitation specifically targeting this vulnerability has been reported to CISA at this time. This vulnerability is not exploitable remotely. This vulnerability has a high attack complexity.
  • Initial Release Date: 2026-04-02
2026-04-02 1 Initial Republication of YSAR-26-0003
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-092-02
