Successful exploitation of these vulnerabilities could allow an attacker to redirected users to malicious sites, decrypt communications, perform a man-in-the-middle (MITM) attack, execute malicious scripts, steal files, and perform other various attacks.
The following versions of Yokogawa FAST/TOOLS are affected:
- FAST/TOOLS >=R9.01|<=R10.04 (CVE-2025-66594, CVE-2025-66595, CVE-2025-66597, CVE-2025-66598, CVE-2025-66599, CVE-2025-66600, CVE-2025-66601, CVE-2025-66602, CVE-2025-66603, CVE-2025-66604, CVE-2025-66605, CVE-2025-66606, CVE-2025-66607, CVE-2025-66608)
| v3 8.2 | Yokogawa | Yokogawa FAST/TOOLS | Generation of Error Message Containing Sensitive Information, Cross-Site Request Forgery (CSRF), Use of a Broken or Risky Cryptographic Algorithm, Exposure of Sensitive System Information to an Unauthorized Control Sphere, Improperly Implemented Security Check for Standard, Reliance on IP Address for Authentication, Cleartext Transmission of Sensitive Information, Exposure of Private Personal Information to an Unauthorized Actor, Improper Neutralization of Invalid Characters in Identifiers in Web Pages, Path Traversal: '\..\filename' |
- Critical Infrastructure Sectors: Critical Manufacturing, Energy, Food and Agriculture
- Company Headquarters Location: Japan
CVE-2025-66594
Detailed messages are displayed on the error page. This information could be exploited by an attacker for other attacks.
Yokogawa FAST/TOOLS
Yokogawa
Yokogawa FAST/TOOLS: >=R9.01|<=R10.04
Yokogawa recommends users update to revision R10.04 and apply patch software (CS_e12787). After the patch is applied, users should apply R10.04 SP3.
Yokogawa strongly recommends that all users establish and maintain a comprehensive security program, not just for addressing the vulnerability identified in this YSAR. Security program components include patch updates, antivirus software, backup and recovery solutions, zoning, hardening, whitelisting, firewalls, and other related measures. Yokogawa can assist organizations in setting up and continuously maintaining a security program. As a starting point for developing the most effective risk mitigation plan, Yokogawa offers security risk assessment services.
For questions related to this report, please contact Yokogawa https://contact.yokogawa.com/cs/gw?c-id=000498.
Relevant CWE: CWE-209 Generation of Error Message Containing Sensitive Information
| 3.1 | 5.3 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:N/A:N |
CVE-2025-66595
This product is vulnerable to cross-site request forgery (CSRF). When a user accesses a link crafted by an attacker, the user's account could be compromised.
Yokogawa FAST/TOOLS
Yokogawa
Relevant CWE: CWE-352 Cross-Site Request Forgery (CSRF)
| 3.1 | 5.3 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:L/A:N |
CVE-2025-66597
This product supports weak cryptographic algorithms, potentially allowing an attacker to decrypt communications with the web server.
Yokogawa FAST/TOOLS
Yokogawa
Relevant CWE: CWE-327 Use of a Broken or Risky Cryptographic Algorithm
| 3.1 | 8.2 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:L/A:N |
CVE-2025-66598
This product supports old SSL/TLS versions, potentially allowing an attacker to decrypt communications with the web server.
Yokogawa FAST/TOOLS
Yokogawa
| 3.1 | 7.1 | HIGH | CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:L/A:N |
CVE-2025-66599
Physical paths could be displayed on web pages. This information could be exploited by an attacker for other attacks.
Yokogawa FAST/TOOLS
Yokogawa
Relevant CWE: CWE-497 Exposure of Sensitive System Information to an Unauthorized Control Sphere
CVE-2025-66600
This product lacks HSTS (HTTP Strict Transport Security) configuration. When an attacker performs a Man in the middle (MITM) attack, communications with the web server could be sniffed.
Yokogawa FAST/TOOLS
Yokogawa
Relevant CWE: CWE-358 Improperly Implemented Security Check for Standard
CVE-2025-66601
This product does not specify MIME types. When an attacker performs a content sniffing attack, malicious scripts could be executed.
Yokogawa FAST/TOOLS
Yokogawa
| 3.1 | 6.5 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:N |
CVE-2025-66602
The web server accepts access by IP address. When a worm that randomly searches for IP addresses intrudes into the network, it could potentially be attacked by the worm.
Yokogawa FAST/TOOLS
Yokogawa
Relevant CWE: CWE-291 Reliance on IP Address for Authentication
CVE-2025-66603
The web server accepts the OPTIONS method. An attacker could potentially use this information to carry out other attacks.
Yokogawa FAST/TOOLS
Yokogawa
| 3.1 | 3.1 | LOW | CVSS:3.1/AV:N/AC:H/PR:N/UI:R/S:U/C:L/I:N/A:N |
CVE-2025-66604
The library version could be displayed on the web page. This information could be exploited by an attacker for other attacks.
Yokogawa FAST/TOOLS
Yokogawa
CVE-2025-66605
Since there are input fields on this web page with the autocomplete attribute enabled, the input content could be saved in the browser the user is using.
Yokogawa FAST/TOOLS
Yokogawa
Relevant CWE: CWE-359 Exposure of Private Personal Information to an Unauthorized Actor
CVE-2025-66606
This product does not properly encode URLs. An attacker could tamper with web pages or execute malicious scripts.
Yokogawa FAST/TOOLS
Yokogawa
Relevant CWE: CWE-86 Improper Neutralization of Invalid Characters in Identifiers in Web Pages
| 3.1 | 3.4 | LOW | CVSS:3.1/AV:N/AC:H/PR:N/UI:R/S:C/C:L/I:N/A:N |
CVE-2025-66607
The response header contains an insecure setting. Users could be redirected to malicious sites by an attacker.
Yokogawa FAST/TOOLS
Yokogawa
| 3.1 | 3.7 | LOW | CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:N/I:L/A:N |
CVE-2025-66608
This product fails to adequately validate URLs. An attacker could send maliciously crafted requests to gain unauthorized access to files on the web server.
Yokogawa FAST/TOOLS
Yokogawa
Relevant CWE: CWE-29 Path Traversal: '\..\filename'
| 3.1 | 7.5 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N |
- Yokogawa reported these vulnerabilities to CISA
| 2026-02-10 | 1 | Initial Republication of YSAR-26-0001-E |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-041-01
