Successful exploitation of these vulnerabilities could allow an attacker to remotely control other users' smart home devices, intercept sensitive data, and hijack sessions.
The following versions of YoSmart YoLink Smart Hub are affected:
- YoSmart server (CVE-2025-59449, CVE-2025-59451)
- YoLink Smart Hub (CVE-2025-59452)
- YoLink Mobile Appication (CVE-2025-59448)
| v3 5.8 | YoSmart | YoSmart YoLink Smart Hub | Incorrect Authorization, Generation of Predictable Numbers or Identifiers, Cleartext Transmission of Sensitive Information |
- Critical Infrastructure Sectors: Communications
CVE-2025-59449
The YoSmart YoLink MQTT broker through 2025-10-02 does not enforce sufficient authorization controls to prevent cross-account attacks, allowing an attacker to remotely operate affected devices if the attacker obtains the associated device IDs. Because YoLink device IDs are predictable, an attacker can exploit this to gain full control over any other YoLink user's devices.
YoSmart
YoSmart server: vers:all/*
YoSmart recommends that users take the following actions to mitigate these vulnerabilities:
CVE-2025-59449 & CVE-2025-59451 - YoSmart's engineering team resolved these vulnerabilities on the server backend. No user actions are required
For more information visit the YoSmart Security Advisory.
Relevant CWE: CWE-863 Incorrect Authorization
| 3.1 | 4.9 | MEDIUM | CVSS:3.1/AV:N/AC:H/PR:L/UI:N/S:C/C:L/I:L/A:N |
CVE-2025-59452
The YoSmart YoLink API through 2025-10-02 uses an endpoint URL that is derived from a device's MAC address along with an MD5 hash of non-secret information, such as a key that begins with cf50.
YoSmart
YoSmart YoLink Smart Hub: 0382
CVE-2025-59452 - YoSmart released update 0383 to support a new, dynamic authentication algorithm. This will be released as an automatic over-the-air update and no user action is required.
Relevant CWE: CWE-340 Generation of Predictable Numbers or Identifiers
| 3.1 | 5.8 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:C/C:L/I:N/A:N |
CVE-2025-59448
Components of the YoSmart YoLink ecosystem through 2025-10-02 leverage unencrypted MQTT to communicate over the internet. An attacker with the ability to monitor network traffic could therefore obtain sensitive information or tamper with the traffic to control affected devices. This affects YoLink Mobile Application 1.40.41 and YoLink MQTT Broker.
YoSmart
YoSmart YoLink Mobile Appication:
CVE-2025-59448 - YoSmart recommends that users update to version 1.40.45 or later to mitigate this vulnerability.
| 3.1 | 4.7 | MEDIUM | CVSS:3.1/AV:A/AC:H/PR:N/UI:N/S:C/C:L/I:L/A:N |
CVE-2025-59451
The YoSmart YoLink application through 2025-10-02 has session tokens with unexpectedly long lifetimes.
YoSmart
| 3.1 | 3.5 | LOW | CVSS:3.1/AV:N/AC:H/PR:L/UI:N/S:C/C:N/I:L/A:N |
- Nick Cerne of Bishop Fox reported these vulnerabilities to CISA
- Initial Release Date: 2026-01-13
| 2026-01-13 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-013-03
