- CVSS v3 9.8
- Vendor: Schneider Electric
- Equipment: PrismaSeT Active - Wireless Panel Server
- Vulnerability: Buffer Copy without Checking Size of Input ('Classic Buffer Overflow')
Successful exploitation of this vulnerability could allow unauthorized code execution, which could result in the unavailability of the PrismaSeT Active - Wireless Panel Server for voltage loss monitoring.
The following versions of Schneider Electric products are affected:
- PrismaSeT Active - Wireless Panel Server: All versions
3.2.1 BUFFER COPY WITHOUT CHECKING SIZE OF INPUT ('CLASSIC BUFFER OVERFLOW') CWE-120
Buffer Copy without Checking Size of Input ('Classic Buffer Overflow'), Out-of-bounds Write, Download of Code Without Integrity Check vulnerability in Silicon Labs Gecko Bootloader on ARM (Firmware Update File Parser modules) allows Code Injection, Authentication Bypass.This issue affects "Standalone" and "Application" versions of Gecko Bootloader.
CVE-2023-4041 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
- CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Critical Manufacturing, Energy
- COMPANY HEADQUARTERS LOCATION: France
Schneider Electric reported this vulnerability to CISA.
PrismaSeT Active - Wireless Panel Server product has reached its end of life and is no longer supported.
Users should immediately apply the following mitigations to reduce the risk of exploit:
- Deactivate Bluetooth Low (BLE) communication of Wireless Panel Server when it is not in use.
- Periodically review audit logs and/or EcoStruxure Facility Expert App security notifications to detect unexpected behaviors.
- Regularly check the physical security of the Wireless Panel Server to protect against unauthorized Bluetooth pairing.
- Use only Schneider Electric official EcoStruxure Power Commission App and EcoStruxure Facility Expert App available in Google Play Store and Apple App Store.
- Do not use EcoStruxure Power Commission App and EcoStruxure Facility Expert App in rooted or jail-broken mobile devices.
- Follow PrismaSeT Active – Wireless Panel Server Cybersecurity Recommendations.
To ensure you are informed of all updates, including details on affected products and remediation plans, subscribe to Schneider Electric's security notification service here: https://www.se.com/en/work/support/cybersecurity/security-notifications.jsp
Schneider Electric strongly recommends the following industry cybersecurity best practices:
- Locate control and safety system networks and remote devices behind firewalls and isolate them from the business network.
- Install physical controls so no unauthorized personnel can access your industrial control and safety systems, components, peripheral equipment, and networks.
- Place all controllers in locked cabinets and never leave them in the "Program" mode.
- Never connect programming software to any network other than the network intended for that device.
- Scan all methods of mobile data exchange with the isolated network such as CDs, USB drives, etc. before use in the terminals or any node connected to these networks.
- Never allow mobile devices that have connected to any other network besides the intended network to connect to the safety or control networks without proper sanitation.
- Minimize network exposure for all control system devices and systems and ensure that they are not accessible from the Internet.
- When remote access is required, use secure methods, such as Virtual Private Networks (VPNs). Recognize that VPNs may have vulnerabilities and should be updated to the most current version available. Also, understand that VPNs are only as secure as the connected devices.
For more information see the associated Schneider Electric CPCERT security advisory SEVD-2025-133-04 PrismaSeT Active - Wireless Panel Server - SEVD-2025-133-04 PDF Version, PrismaSeT Active - Wireless Panel Server - SEVD-2025-133-04 CSAF Version.
- May 20, 2025: Initial Republication of Schneider Electric CPCERT SEVD-2025-133-04
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-140-06
