- CVSS v4 9.3
- Vendor: Rockwell Automation
- Equipment: 95057C-FTHTWXCT11
- Vulnerability: Improper Restriction of XML External Entity Reference
Successful exploitation of this vulnerability could allow an attacker to launch XXE-based attacks on applications that accept malicious log4net configuration files.
The following versions of Rockwell Automation FactoryTalk Historian ThingWorx are affected:
- 95057C-FTHTWXCT11: Versions v4.02.00 and prior
3.2.1 IMPROPER RESTRICTION OF XML EXTERNAL ENTITY REFERENCE CWE-611
Apache log4net versions before 2.0.10 do not disable XML external entities when parsing log4net configuration files. This allows for XXE-based attacks in applications that accept attacker-controlled log4net configuration files.
CVE-2018-1285 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2018-1285. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Rockwell Automation released a product update addressing this vulnerability:
- 95057C-FTHTWXCT11: Versions v5.00.00 and later
For information on how to mitigate security risks on industrial automation control systems, Rockwell Automation encourages users to implement their suggested security best practices to minimize the risk of the vulnerability.
For more information, see Rockwell Automation Security Advisory SD1728.
- May 22, 2025: Initial Republication of Rockwell Automation SD1728
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-142-02
