CyberData 011209 SIP Emergency Intercom
Jun 5, 2025, 4:25 PM UTC
  • CVSS v4 9.3
  • Vendor: CyberData
  • Equipment: 011209 SIP Emergency Intercom
  • Vulnerabilities: Authentication Bypass Using an Alternate Path or Channel, Missing Authentication for Critical Function, SQL Injection, Insufficiently Protected Credentials, Path Traversal: '.../...//'
Successful exploitation of these vulnerabilities could allow an attacker to disclose sensitive information, cause a denial-of-service condition, or achieve code execution.
The following CyberData products are affected:
  • 011209 SIP Emergency Intercom: Versions prior to 22.0.1
3.2.1 Authentication Bypass Using an Alternate Path or Channel CWE-288
011209 Intercom could allow an unauthenticated user access to the Web Interface through an alternate path.
CVE-2025-30184 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-30184. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.2 Missing Authentication for Critical Function CWE-306
011209 Intercom exposes features that could allow an unauthenticated to gain access and cause a denial-of-service condition or system disruption.
CVE-2025-26468 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-26468. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.3 Improper Neutralization of Special Elements used in an SQL Command ('SQL Injection') CWE-89
011209 Intercom could allow an unauthenticated user to gather sensitive information through blind SQL injections.
CVE-2025-30507 has been assigned to this vulnerability. A CVSS v3.1 base score of 5.3 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-30507. A base score of 6.9 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:L/VI:N/VA:N/SC:N/SI:N/SA:N).
3.2.4 Insufficiently Protected Credentials CWE-522
011209 Intercom does not properly store or protect web server admin credentials.
CVE-2025-30183 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-30183. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
3.2.5 Path Traversal: '.../...//' CWE-35
011209 Intercom could allow an authenticated attacker to upload arbitrary files to multiple locations within the system.
CVE-2025-30515 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-30515. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Communications, Emergency Services, Commercial Facilities
Vera Mens of Claroty Team82 reported these vulnerabilities to CISA.
CyberData recommends users update to v22.0.1
  • June 5, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-155-01
