- CVSS v3 9.8
- Vendor: Hitachi Energy
- Equipment: Relion 670, Relion 650, SAM600-IO
- Vulnerabilities: Integer Overflow or Wraparound
Successful exploitation of these vulnerabilities could allow an attacker to cause memory corruption on the products.
Hitachi Energy reports that the following products are affected:
- Relion 670/650/SAM600-IO series: Version 2.2.5 revisions up to 2.2.5.1
- Relion 670/650 series: Version 2.2.4 revisions up to 2.2.4.2
- Relion 670 series: Version 2.2.3 revisions up to 2.2.3.4
- Relion 670 series: Version 2.2.2 revisions up to 2.2.2.4
- Relion 670/650/SAM600-IO series: Version 2.2.1 revisions up to 2.2.1.7
- Relion 670/650 series version 2.2.0: All revisions
- Relion 670/650 series version 2.1: All revisions
- Relion 670 series version 2.0: All revisions
- Relion 670 series version 1.2: All revisions
- Relion 670 series version 1.1: All revisions
- Relion 650 series version 1.3: All revisions
- Relion 650 series version 1.2: All revisions
- Relion 650 series version 1.1: All revisions
- Relion 650 series version 1.0: All revisions
3.2.1 INTEGER OVERFLOW OR WRAPAROUND CWE-190
In Wind River VxWorks, memory allocator has a possible overflow in calculating the memory block's size to be allocated by calloc(). As a result, the actual memory allocated is smaller than the buffer size specified by the arguments, leading to memory corruption.
CVE-2020-28895 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.3 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:L).
3.2.2 INTEGER OVERFLOW OR WRAPAROUND CWE-190
An issue was discovered in Wind River VxWorks 7. The memory al-locator has a possible integer overflow in calculating a memory block's size to be allocated by calloc(). As a result, the actual memory allocated is smaller than the buffer size specified by the arguments, leading to memory corruption.
CVE-2020-35198 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
- CRITICAL INFRASTRUCTURE SECTORS: Energy
- COMPANY HEADQUARTERS LOCATION: Switzerland
Hitachi Energy reported these vulnerabilities to CISA.
Hitachi Energy has identified the following specific workarounds and mitigations users may apply to reduce risk:
- Relion 670 series version 2.2.5 revisions up to 2.2.5.1, Relion 650 series version 2.2.5 revisions up to 2.2.5.1, SAM-IO series version 2.2.5 revisions up to 2.2.5.1: Update to 2.2.5.2 version or latest
- Relion 670 series version 2.2.4 revisions up to 2.2.4.2, Relion 650 series version 2.2.4 revisions up to 2.2.4.2: Update to 2.2.4.3 version or latest
- Relion 670 series version 2.2.3 revisions up to 2.2.3.4: Update to 2.2.3.5 version or latest
- Relion 670 series version 2.2.2 revisions up to 2.2.2.4: Update to 2.2.2.5 version or latest
- Relion 670 series version 2.2.1 revisions up to 2.2.1.7, Relion 650 series version 2.2.1 revisions up to 2.2.1.7, SAM-IO series version 2.2.1 revisions up to 2.2.1.7: Update to 2.2.1.8 version or latest
- Relion 670 series version 1.1 to 2.2.0 all revisions, Relion 650 series version 1.0 to 2.2.0 all revisions: Refer to the Mitigation Factors/Workaround Section for the current mitigation strategy.
For more information see the associated Hitachi Energy PSIRT security advisory 8DBD000070 Cybersecurity Advisory - BadAlloc – Memory Allocation Vulnerabilities in Hitachi Energy Relion 670, 650 series and SAM600-IO Product.
- June 5, 2025: Initial Republication of Hitachi Energy 8DBD000070
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-155-02
