- CVSS v4 8.8
- ATTENTION: Exploitable remotely/Low attack complexity
- Vendor: SinoTrack
- Equipment: All Known SinoTrack Devices
- Vulnerabilities: Weak Authentication, Observable Response Discrepency
Successful exploitation of these vulnerabilities could allow an attacker to access device profiles without authorization through the common web management interface. Access to the device profile may allow an attacker to perform some remote functions on connected vehicles such as tracking the vehicle location and disconnecting power to the fuel pump where supported.
The following SinoTrack products are affected:
- SinoTrack IOT PC Platform: All versions
3.2.1 WEAK AUTHENTICATION CWE-1390
A username and password are required to authenticate to the central SinoTrack device management interface. The username for all devices is an identifier printed on the receiver. The default password is well-known and common to all devices. Modification of the default password is not enforced during device setup. A malicious actor can retrieve device identifiers with either physical access or by capturing identifiers from pictures of the devices posted on publicly accessible websites such as eBay.
CVE-2025-5484 has been assigned to this vulnerability. A CVSS v3 base score of 8.3 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:L).
A CVSS v4 score has also been calculated for CVE-2025-5484. A base score of 7.6 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:P/PR:N/UI:P/VC:H/VI:H/VA:L/SC:N/SI:N/SA:L).
3.2.2 OBSERVABLE RESPONSE DISCREPENCY CWE-204
User names used to access the web management interface are limited to the device identifier, which is a numerical identifier no more than 10 digits. A malicious actor can enumerate potential targets by incrementing or decrementing from known identifiers or through enumerating random digit sequences.
CVE-2025-5485 has been assigned to this vulnerability. A CVSS v3 base score of 8.6 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:L/A:L).
A CVSS v4 score has also been calculated for CVE-2025-5485. A base score of 8.8 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:L/VA:L/SC:N/SI:N/SA:L).
- CRITICAL INFRASTRUCTURE SECTORS: Communications
- COMPANY HEADQUARTERS LOCATION: China
Raúl Ignacio Cruz Jiménez reported these vulnerabilities to CISA.
SinoTrack did not respond to CISA's request for coordination. Please contact SinoTrack for more information.
CISA recommends that device users take defensive measures to minimize the risk of exploitation of these vulnerabilities, including:
- Change the default password to a unique, complex password as soon as is practical in the management interface available at https://sinotrack.com/.
- Conceal the device identifier. If the sticker is visible on publicly accessible photographs, consider deleting or replacing the pictures to protect the identifier.
- June 10, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-160-01
