Delta Electronics CNCSoft
Jun 24, 2025, 4:46 PM UTC
  • CVSS v4 7.3
  • Vendor: Delta Electronics
  • Equipment: CNCSoft
  • Vulnerabilities: Out-of-bounds Write
Successful exploitation of these vulnerabilities could allow an attacker to execute code within the context of the current process.
Delta Electronics reports the following versions of CNCSoft, a human-machine interface, are affected:
  • CNCSoft: v1.01.34 and prior
Delta Electronics CNCSoft does not properly validate user-supplied files. If a user opens a maliciously crafted file, an attacker can leverage this vulnerability to execute code within the context of the current process.
CVE-2025-47724 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.7 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:H/UI:R/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-47724. A base score of 7.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:P/PR:H/UI:A/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
CVE-2025-47725 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.7 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:H/UI:R/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-47725. A base score of 7.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:P/PR:H/UI:A/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
3.2.3 OUT-OF-BOUNDS WRITE CWE-787
CVE-2025-47726 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.7 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:H/UI:R/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-47726. A base score of 7.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:P/PR:H/UI:A/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
3.2.4 OUT-OF-BOUNDS WRITE CWE-787
CVE-2025-47727 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.7 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:H/UI:R/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-47727. A base score of 7.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:P/PR:H/UI:A/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
Natnael Samson working with Trend Micro Zero Day Initiative reported these vulnerabilities to CISA.
Delta Electronics does not plan to address these vulnerabilities because the A-series CNC products supported by CNCSoft have been discontinued. CNCSoft will be removed from the Delta Download Center. Delta recommends users migrate to newer Delta CNC products along with their corresponding software as soon as possible.
Delta Electronics offers the following general recommendations:
  • Do not click on untrusted Internet links or open unsolicited email attachments.
  • Place systems and devices behind a firewall and isolate them from the business network.
For any product-related support inquiries, contact Delta through the company's portal page to request any information or materials you may need.
Reference Delta's product cybersecurity advisory for more information about these vulnerabilities.
CISA recommends users take defensive measures to minimize the risk of exploitation of these vulnerabilities. CISA reminds organizations to perform proper impact analysis and risk assessment prior to deploying defensive measures.
  • June 24, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-175-02
