Mitsubishi Electric Air Conditioning Systems
Jun 26, 2025, 4:12 PM UTC
  • CVSS v4 9.3
  • Vendor: Mitsubishi Electric
  • Equipment: Air conditioning systems
  • Vulnerability: Missing Authentication for Critical Function
Successful exploitation of this vulnerability could allow an attacker to control the air conditioning system.
Mitsubishi Electric reports the following air conditioning systems are affected:
  • G-50: Ver.3.37 and prior
  • G-50-W: Ver.3.37 and prior
  • G-50A: Ver.3.37 and prior
  • GB-50: Ver.3.37 and prior
  • GB-50A: Ver.3.37 and prior
  • GB-24A: Ver.9.12 and prior
  • G-150AD: Ver.3.21 and prior
  • AG-150A-A: Ver.3.21 and prior
  • AG-150A-J: Ver.3.21 and prior
  • GB-50AD: Ver.3.21 and prior
  • GB-50ADA-A: Ver.3.21 and prior
  • GB-50ADA-J: Ver.3.21 and prior
  • EB-50GU-A: Ver.7.11 and prior
  • EB-50GU-J: Ver.7.11 and prior
  • AE-200J: Ver.8.01 and prior
  • AE-200A: Ver.8.01 and prior
  • AE-200E: Ver.8.01 and prior
  • AE-50J: Ver.8.01 and prior
  • AE-50A: Ver.8.01 and prior
  • AE-50E: Ver.8.01 and prior
  • EW-50J: Ver.8.01 and prior
  • EW-50A: Ver.8.01 and prior
  • EW-50E: Ver.8.01 and prior
  • TE-200A: Ver.8.01 and prior
  • TE-50A: Ver.8.01 and prior
  • TW-50A: Ver.8.01 and prior
  • CMS-RMD-J: Ver.1.40 and prior
An authentication bypass vulnerability exists in Mitsubishi Electric air conditioning systems. An attacker may bypass authentication to control the air conditioning systems illegally or disclose information from them by exploiting this vulnerability. In addition, the attacker may tamper with the firmware of the affected products using the disclosed information.
CVE-2025-3699 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-3699. A base score of 9.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities
Mihály Csonka reported this vulnerability to Mitsubishi Electric.
Mitsubishi Electric is currently preparing improved versions of the following products to mitigate this vulnerability: AE-200J, AE-200A, AE-200E, AE-50J, AE-50A, AE-50E, EW-50J, EW-50A, EW-50E, TE-200A, TE-50A, and TW-50A.
To minimize the exploitation risk of this vulnerability, make sure air conditioning systems are configured correctly as recommended by Mitsubishi Electric. Mitsubishi Electric recommends taking the following mitigation measures:
  • Restrict the access to air conditioning systems from untrusted networks and hosts.
  • Restrict physical access to air conditioning systems, computers which can access them, and the network which is connected to them.
  • Use antivirus software and update the OS and the web browser to the latest version on computers that connect to air conditioning systems.
See Mitsubishi Electric's security bulletin for more information.
  • June 26, 2025: Initial Republication of Mitsubishi Electric 2025-004.
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-177-01
