Voltronic Power and PowerShield UPS Monitoring Software
Jul 1, 2025, 4:57 PM UTC
  • CVSS v4 10.0
  • Vendor: Voltronic Power, PowerShield
  • Equipment: Viewpower, NetGuard
  • Vulnerabilities: Exposed Dangerous Method or Function, Forced Browsing
Successful exploitation of these vulnerabilities could allow an unauthenticated attacker remotely to make configuration changes, resulting in shutting down UPS connected devices or execution of arbitrary code.
The following Voltronic Power and PowerShield UPS monitoring software is affected, as well as other derivative products:
  • Voltronic Power Viewpower: Version 1.04-24215 and prior
  • Voltronic Power ViewPower Pro: Version 2.2165 and prior
  • Powershield NetGuard: Version 1.04-22119 and prior
3.2.1 EXPOSED DANGEROUS METHOD OR FUNCTION CWE-749
The UPS management software normally allows a properly authenticated and authorized user using a web interface to configure the system to run a single OS command of the users choosing when the software detects a managed UPS is shutting down. A related critical underlying function is exposed over the network with no authentication or authorization allowing an attacker to use this to run arbitrary code immediately regardless of any managed UPS state or presence.
CVE-2022-31491 has been assigned to this vulnerability. A CVSS v3.1 base score of 10.0 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2022-31491. A base score of 10.0 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
3.2.2 DIRECT REQUEST ('FORCED BROWSING') CWE-425
The UPS management software is supposed to only allow a properly authenticated and authorized admin user using a web interface to configure the system. An unauthenticated remote attacker can make changes to the system including: changing the web interface admin password, view/change system configuration, enumerate connected UPS devices and shut down connected UPS devices.
CVE-2022-43110 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2022-43110. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • COMPANY HEADQUARTERS LOCATION: Voltronic Power - Taiwan, Powershield - Australia
An anonymous researcher reported these vulnerabilities to CISA.
Voltronic Power has not responded to requests to work with CISA to mitigate these vulnerabilities. Users of these affected products are invited to contact Voltronic Power customer support for additional information.
Powershield is aware of the issue and has provided a fix in NetGuard versions 1.04-23292 and later. For more information, refer to Powershield's software page. User can also contact Powershield via email or phone: +618 9209 3839.
CISA recommends users take defensive measures to minimize the risk of exploitation of this these vulnerabilities, such as:
No known public exploitation specifically targeting this these vulnerabilities has been reported to CISA at this time.
  • July 1, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-182-05
