Mitsubishi Electric MELSEC iQ-F Series
Jul 3, 2025, 4:34 PM UTC
  • CVSS v4 6.9
  • Vendor: Mitsubishi Electric Corporation
  • Equipment: MELSEC iQ-F Series
  • Vulnerability: Overly Restrictive Account Lockout Mechanism
Successful exploitation of this vulnerability could result in a denial-of-service condition for legitimate users for a certain period by repeatedly attempting to log in with incorrect passwords. When the product repeatedly receives unauthorized logins from an attacker, legitimate users will be unable to be authenticated until a certain period has passed after the lockout or until the product is reset.
The following version of MELSEC iQ-F Series is affected:
  • FX5U-32MT/ES: All versions
  • FX5U-32MT/DS: All versions
  • FX5U-32MT/ESS: All versions
  • FX5U-32MT/DSS: All versions
  • FX5U-32MR/ES: All versions
  • FX5U-32MR/DS: All versions
  • FX5U-64MT/ES: All versions
  • FX5U-64MT/DS: All versions
  • FX5U-64MT/ESS: All versions
  • FX5U-64MT/DSS: All versions
  • FX5U-64MR/ES: All versions
  • FX5U-64MR/DS: All versions
  • FX5U-80MT/ES: All versions
  • FX5U-80MT/DS: All versions
  • FX5U-80MT/ESS: All versions
  • FX5U-80MT/DSS: All versions
  • FX5U-80MR/ES: All versions
  • FX5U-80MR/DS: All versions
  • FX5UC-32MT/D: All versions
  • FX5UC-32MT/DSS: All versions
  • FX5UC-64MT/D: All versions
  • FX5UC-64MT/DSS: All versions
  • FX5UC-96MT/D: All versions
  • FX5UC-96MT/DSS: All versions
  • FX5UC-32MT/DS-TS: All versions
  • FX5UC-32MT/DSS-TS: All versions
  • FX5UC-32MR/DS-TS: All versions
  • FX5UJ-24MT/ES: All versions
  • FX5UJ-24MT/DS: All versions
  • FX5UJ-24MT/ESS: All versions
  • FX5UJ-24MT/DSS: All versions
  • FX5UJ-24MR/ES: All versions
  • FX5UJ-24MR/DS: All versions
  • FX5UJ-40MT/ES: All versions
  • FX5UJ-40MT/DS: All versions
  • FX5UJ-40MT/ESS: All versions
  • FX5UJ-40MT/DSS: All versions
  • FX5UJ-40MR/ES: All versions
  • FX5UJ-40MR/DS: All versions
  • FX5UJ-60MT/ES: All versions
  • FX5UJ-60MT/DS: All versions
  • FX5UJ-60MT/ESS: All versions
  • FX5UJ-60MT/DSS: All versions
  • FX5UJ-60MR/ES: All versions
  • FX5UJ-60MR/DS: All versions
  • FX5UJ-24MT/ES-A: All versions
  • FX5UJ-24MR/ES-A: All versions
  • FX5UJ-40MT/ES-A: All versions
  • FX5UJ-40MR/ES-A: All versions
  • FX5UJ-60MT/ES-A: All versions
  • FX5UJ-60MR/ES-A: All versions
  • FX5S-30MT/ES: All versions
  • FX5S-30MT/DS: All versions
  • FX5S-30MT/ESS: All versions
  • FX5S-30MT/DSS: All versions
  • FX5S-30MR/ES: All versions
  • FX5S-30MR/DS: All versions
  • FX5S-40MT/ES: All versions
  • FX5S-40MT/DS: All versions
  • FX5S-40MT/ESS: All versions
  • FX5S-40MT/DSS: All versions
  • FX5S-40MR/ES: All versions
  • FX5S-40MR/DS: All versions
  • FX5S-60MT/ES: All versions
  • FX5S-60MT/DS: All versions
  • FX5S-60MT/ESS: All versions
  • FX5S-60MT/DSS: All versions
  • FX5S-60MR/ES: All versions
  • FX5S-60MR/DS: All versions
  • FX5S-80MT/ES: All versions
  • FX5S-80MT/ESS: All versions
  • FX5S-80MR/ES: All versions
  • FX5-CCLGN-MS: All versions
3.2.1 OVERLY RESTRICTIVE ACCOUNT LOCKOUT MECHANISM CWE-645
A denial-of-service (DoS) vulnerability exists in the MELSEC iQ-F series due to an overly restrictive account lockout mechanism. A remote attacker could lockout a legitimate user for a certain period of time by repeatedly attempting to login with an incorrect password.
CVE-2025-5241 has been assigned to this vulnerability. A CVSS v3 base score of 5.3 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:L).
A CVSS v4 score has also been calculated for CVE-2025-5241. A base score of 6.9 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:L/SC:N/SI:N/SA:N).
Thai Do, Minh Pham, Quan Le, and Loc Nguyen of OPSWAT Unit 515 reported this vulnerability to Mitsubishi Electric.
Mitsubishi Electric Corporation has stated there are no plans to release a fixed version. Implement the following mitigation measures to minimize the risk of exploiting this vulnerability:
  • Use a firewall or virtual private network (VPN), etc. to prevent unauthorized access when Internet access is required.
  • Use within a LAN and block access from untrusted networks and hosts through firewalls.
  • Restrict physical access to the affected products and the LAN that is connected to them.
  • Use IP filter function to block access from untrusted hosts.
    • NOTE: For details on the IP filter function, please refer to the following manual for each product.
    • "13.1 IP Filter Function" in the MELSEC iQ-F FX5 User's Manual (Communication)
    • "4.5 Security" in the MELSEC iQ-F FX5 CC-Link IE TSN Master/Local Module User's Manual
Mitsubishi Electric Corporation recommends downloading the manual from the following Mitsubishi Electric Website.
See Mitsubishi Electric's security bulletin for more information.
  • When remote access is required, use more secure methods, such as VPNs, recognizing VPNs may have vulnerabilities and should be updated to the most current version available. Also recognize VPN is only as secure as the connected devices.
  • July 3, 2025: Initial Republication of Mitsubishi Electric 2025-005
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-184-04
