Siemens TIA Administrator
Jul 10, 2025, 4:02 PM UTC
  • CVSS v4 8.5
  • Equipment: TIA Administrator
  • Vulnerabilities: Improper Verification of Cryptographic Signature, Improper Access Control
Successful exploitation of these vulnerabilities could allow an attacker to escalate privilege or execute arbitrary code during installations.
  • TIA Administrator: All versions prior to V3.0.6
3.2.1 IMPROPER VERIFICATION OF CRYPTOGRAPHIC SIGNATURE CWE-347
The affected application improperly validates code signing certificates. This could allow an attacker to bypass the check and execute arbitrary code during installations.
CVE-2025-23364 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.2 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-23364. A base score of 6.9 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:N/UI:N/VC:N/VI:H/VA:N/SC:N/SI:N/SA:N).
3.2.2 IMPROPER ACCESS CONTROL CWE-284
The affected application allows low-privileged users to trigger installations by overwriting cache files and modifying the downloads path. This would allow an attacker to escalate privilege and execute arbitrary code.
CVE-2025-23365 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-23365. A base score of 8.5 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Siemens reported these vulnerabilities to CISA.
For more information see the associated Siemens security advisory SSA-573669 in HTML and CSAF.
  • July 10, 2025: Initial Republication of Siemens SSA-573669
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-191-03
