LG Innotek Camera Model LNV5110R
Jul 24, 2025, 4:35 PM UTC
  • CVSS v4 8.3
  • Vendor: LG Innotek
  • Equipment: Camera Model LNV5110R
  • Vulnerability: Authentication Bypass Using an Alternate Path or Channel
Successful exploitation of this vulnerability could allow an attacker to gain administrative access to the device.
The following model of LG Innotek CCTV Camera is affected:
  • LNV5110R: All versions
3.2 Vulnerability Overview
3.2.1 AUTHENTICATION BYPASS USING AN ALTERNATE PATH OR CHANNEL CWE-288
An authentication vulnerability exists in the LG Innotek camera model LNV5110R firmware that allows a malicious actor to upload an HTTP POST request to the devices non-volatile storage. This action may result in remote code execution that allows an attacker to run arbitrary commands on the target device at the administrator privilege level.
CVE-2025-7742 has been assigned to this vulnerability. A CVSS v3 base score of 7.0 has been calculated; the CVSS vector string is (AV:N/AC:H/PR:N/UI:N/S:U/C:H/I:L/A:L).
A CVSS v4 score has also been calculated for CVE-2025-7742. A base score of 8.3 has been calculated; the CVSS vector string is (AV:N/AC:H/AT:N/PR:N/UI:N/VC:H/VI:L/VA:L/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities
  • COMPANY HEADQUARTERS LOCATION: South Korea
Souvik Kandar reported this vulnerability to CISA.
LG Innotek is aware of the vulnerability but has noted this is an end-of-life product that can no longer be patched.
Please visit the LG Security Center for further guidance.
  • July 24, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-205-04
