- CVSS v4 8.4
- Vendor: Delta Electronics
- Equipment: DTN Soft
- Vulnerability: Deserialization of Untrusted Data
Successful exploitation of this vulnerability could allow an attacker to use a specially crafted project file to execute arbitrary code.
The following Delta Electronics products are affected:
- DTN Soft: Versions 2.1.0 and prior
3.2 Vulnerability Overview
3.2.1 DESERIALIZATION OF UNTRUSTED DATA CWE-502
The affected product is affected by a deserialization of untrusted data vulnerability, which could allow an attacker to use a specially crafted project file to execute arbitrary code.
CVE-2025-53416 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-53416. A base score of 8.4 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:N/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
- COMPANY HEADQUARTERS LOCATION: Taiwan
kimiya working with Trend Micro Zero Day Initiative reported this vulnerability to CISA.
According to Delta Electronics, if a version of DTN Soft prior to v2.1.0 is installed, it should be updated to v2.1.0 or later. If DTM Soft is also installed, it should be updated to v1.6.0.0 (released on March 25, 2025) or later. The update can be obtained from Delta Electronics' Download Center.
For more information, please see Delta Electronics' advisory Delta-PCSA-2025-00009..
- July 29, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-210-03
