Johnson Controls FX80 and FX90
Aug 7, 2025, 4:13 PM UTC
  • CVSS v4 8.4
  • Vendor: Johnson Controls Inc.
  • Equipment: FX80 and FX90
  • Vulnerability: Dependency on Vulnerable Third-Party Component
Successful exploitation of this vulnerability could allow an attacker to compromise the device's configuration files.
The following Johnson Controls products are affected:
  • FX80: FX 14.10.10
  • FX80: FX 14.14.1
  • FX90: FX 14.10.10
  • FX90: FX 14.14.1
3.2.1 DEPENDENCY ON VULNERABLE THIRD-PARTY COMPONENT CWE-1395
The affected product is vulnerable to a vulnerable third-party component, which could allow an attacker to compromise device configuration files.
CVE-2025-43867 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.7 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:C/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-43867. A base score of 8.4 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:N/VA:H/SC:H/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Critical Manufacturing, Commercial Facilities, Government Facilities, Transportation Systems, Energy
Johnson Controls reported this vulnerability to CISA.
Johnson Controls recommends users update to the latest version. Successful exploitation of CVE-2025-43867 could trigger CVEs CVE-2025-3936 through CVE-2025-3945.
  • For systems running version 14.10.10, apply the 14.10.11 patch from the software portal.
  • For systems running version 14.14.1, apply the 14.14.2 patch from the software portal.
  • Note: FX 14.10.10 contains Niagara 4.10u10
  • Note: FX 14.14.1 contains Niagara 4.14u1
Login credentials are required to access the software portal.
For more detailed mitigation instructions, visit Johnson Controls Product Security Advisory JCI-PSA-2025-09 v1
  • August 7, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-219-02
