Dreame Technology iOS and Android Mobile Applications
Aug 7, 2025, 4:13 PM UTC
  • CVSS v4 8.5
  • Vendor: Dreame Technology
  • Equipment: Dreamehome and MOVAhome mobile applications
  • Vulnerability: Improper Certificate Validation
Successful exploitation of this vulnerability could result in unauthorized information disclosure.
The following versions of the Dreame and MOVA mobile apps are affected:
  • Dreamehome iOS app: Versions 2.3.4 and prior
  • Dreamehome Android app: Versions 2.1.8.8 and prior
  • MOVAhome iOS app: Versions 1.2.3 and prior
3.2.1 IMPROPER CERTIFICATE VALIDATION CWE-295
A TLS vulnerability exists in the phone application used to manage a connected device. The phone application accepts self-signed certificates when establishing TLS communication which may result in man-in-the-middle attacks on untrusted networks. Captured communications may include user credentials and sensitive session tokens.
CVE-2025-8393 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.3 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-8393. A base score of 8.5 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:N/PR:N/UI:P/VC:H/VI:H/VA:N/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Communications
  • COMPANY HEADQUARTERS LOCATION: China
Dennis Giese reported this vulnerability to CISA.
Dreame Technology did not respond to CISA's request for coordination. Contact Dreame Technology directly for more information. Note that MOVA is a subsidiary of Dreame Technology.
  • August 07, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-219-06
