- CVSS v4 9.3
- Vendor: Rockwell Automation
- Equipment: Micro800
- Vulnerabilities: Dependency on Vulnerable Third-Party Component, Improper Input Validation
Successful exploitation of these vulnerabilities could result in remote code execution or may lead to privilege escalation.
The following versions of Rockwell Automation Micro800 are affected:
- PLC Micro820 LC20: All versions prior to V14.011 (CVE-2023-48691, CVE-2023-48692, CVE-2023-48693)
- PLC Micro850 LC50: All versions prior to V12.013 (CVE-2023-48691, CVE-2023-48692, CVE-2023-48693)
- PLC Micro870 LC70: All versions prior to V12.013 (CVE-2023-48691, CVE-2023-48692, CVE-2023-48693)
- PLC Micro850 L50E: Versions V20.011 through V22.011 (CVE-2023-48691, CVE-2023-48692, CVE-2023-48693, CVE-2025-7693)
- PLC Micro870 L70E: Versions V20.011 through V22.011 (CVE-2023-48691, CVE-2023-48692, CVE-2023-48693, CVE-2025-7693)
3.2.1 DEPENDENCY ON VULNERABLE THIRD-PARTY COMPONENT CWE-1395
Azure RTOS NetX Duo is a TCP/IP network stack designed specifically for deeply embedded real-time and IoT applications. An attacker can cause an out-of-bounds write in Azure RTOS NETX Duo, that could lead to remote code execution.
CVE-2023-48691 has been assigned to this vulnerability. A CVSS v3 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2023-48691. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.2 DEPENDENCY ON VULNERABLE THIRD-PARTY COMPONENT CWE-1395
Azure RTOS NetX Duo is a TCP/IP network stack designed specifically for deeply embedded real-time and IoT applications. An attacker can cause remote code execution due to memory overflow vulnerabilities in Azure RTOS NETX Duo.
CVE-2023-48692 has been assigned to this vulnerability. A CVSS v3 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2023-48692. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.3 DEPENDENCY ON VULNERABLE THIRD-PARTY COMPONENT CWE-1395
Azure RTOS ThreadX is an advanced real-time operating system (RTOS) designed specifically for deeply embedded applications. An attacker can cause arbitrary read and write due to vulnerability in parameter checking mechanism in Azure RTOS ThreadX, which may lead to privilege escalation.
CVE-2023-48693 has been assigned to this vulnerability. A CVSS v3 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2023-48693. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.4 IMPROPER INPUT VALIDATION CWE-20
A security issue exists due to improper handling of malformed CIP Forward Close packets during fuzzing. The controller enters a solid red Fault LED state and becomes unresponsive. Upon power cycle, the controller will enter recoverable fault where the MS LED and Fault LED become flashing red and reports fault code 0xF015. To recover, clear the fault.
CVE-2025-7693 has been assigned to this vulnerability. A CVSS v3 base score of 9.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-7693. A base score of 9.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
- CRITICAL INFRASTRUCTURE SECTORS: Chemical, Critical Manufacturing, Energy, Food and Agriculture, Transportation Systems, Water and Wastewater
Rockwell Automation recommends the following updates:
- PLC Micro820 LC20: Migrate to Micro820 L20E V23.011 and later (this has yet to be released, target to release in Sept 2025)
- PLC Micro850 LC50: Migrate to Micro850 L50E V23.011 and later
- PLC Micro870 LC70: Migrate to Micro870 L70E V23.011 and later
- PLC Micro850 L50E: V23.011 and later
- PLC Micro870 L70E: V23.011 and later
Rockwell Automation also recommends users follow their published Security Best Practices.
- August 14, 2025: Initial Republication: Initial Republication of Rockwell Automation’s SD1736
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-226-25
