- CVSS v4 7.1
- Vendor: Rockwell Automation
- Equipment: 1756-ENT2R, 1756-EN4TR, 1756-EN4TRXT
- Vulnerabilities: Improper Input Validation, Improper Handling of Exceptional Conditions
Successful exploitation of these vulnerabilities could result in an attacker causing a denial of service condition.
The following Rockwell Automation products are affected:
- 1756-ENT2R: Versions prior to 7.001
- 1756-EN4TR: Versions prior to 7.001
- 1756-EN4TRXT: Versions prior to 7.001
A security issue exists in the protected mode of 1756-EN4TR and 1756-ENT2R communication modules, where a Concurrent Forward Close operation can trigger a Major Non-Recoverable (MNFR) fault. This condition may lead to unexpected system crashes and loss of device availability.
CVE-2025-8007 has been assigned to this vulnerability. A CVSS v3 base score of 6.5 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-8007. A base score of 7.1 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.2 IMPROPER HANDLING OF EXCEPTIONAL CONDITIONS CWE-755
A security issue exists in the protected mode of EN4TR devices, where sending specifically crafted messages during a Forward Close operation can cause the device to crash.
CVE-2025-8008 has been assigned to this vulnerability. A CVSS v3 base score of 6.5 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-8008. A base score of 7.1 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
- CRITICAL INFRASTRUCTURE SECTORS: Chemical, Critical Manufacturing
Rockwell Automation recommends users upgrade their devices to 7.001 or later. The update can be downloaded from Rockwell Automation's website.
Rockwell Automation also recommends users follow their published Security Best Practices.
- August 14, 2025: Initial Republication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-226-31
