- CVSS v3 7.1
- ATTENTION: Exploitable from adjacent network/low attack complexity
- Vendor: Siemens
- Equipment: Opcenter Quality
- Vulnerabilities: Incorrect Authorization, Missing Encryption of Sensitive Data, Generation of Error Message Containing Sensitive Information, Insufficient Session Expiration, Use of a Broken or Risky Cryptographic Algorithm
Successful exploitation of these vulnerabilities could allow an attacker to gain complete access of the application, access to sensitive information, access to session information, or execute a Machine-In-The-Middle attack and compromise confidentiality and integrity of data.
- Siemens SmartClient modules Opcenter QL Home (SC): Versions between 13.2 and 2506
- Siemens SOA Audit: Versions between 13.2 and 2506
- Siemens SOA Cockpit: Versions between 13.2 and 2506
3.2.1 INCORRECT AUTHORIZATION CWE-863
The affected application does not enforce mandatory authorization on some functionality level at server side. This could allow an authenticated attacker to gain complete access of the application.
CVE-2024-41979 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.1 has been calculated; the CVSS vector string is (CVSS:3.1/AV:A/AC:H/PR:L/UI:N/S:U/C:H/I:H/A:H).
3.2.2 MISSING ENCRYPTION OF SENSITIVE DATA CWE-311
The affected application do not encrypt the communication in LDAP interface by default. This could allow an authenticated attacker to gain unauthorized access to sensitive information.
CVE-2024-41980 has been assigned to this vulnerability. A CVSS v3.1 base score of 3.1 has been calculated; the CVSS vector string is (CVSS:3.1/AV:A/AC:H/PR:H/UI:N/S:U/C:L/I:L/A:N).
3.2.3 MISSING ENCRYPTION OF SENSITIVE DATA CWE-311
The affected application does not have adequate encryption of sensitive information. This could allow an authenticated attacker to gain access of sensitive information.
CVE-2024-41982 has been assigned to this vulnerability. A CVSS v3.1 base score of 4.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:A/AC:H/PR:L/UI:N/S:U/C:H/I:N/A:N).
3.2.4 GENERATION OF ERROR MESSAGE CONTAINING SENSITIVE INFORMATION CWE-209
The affected application displays SQL statement in the error messages encountered during the generation of reports using Cockpit tool.
CVE-2024-41983 has been assigned to this vulnerability. A CVSS v3.1 base score of 3.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:A/AC:L/PR:L/UI:N/S:U/C:L/I:N/A:N).
3.2.5 GENERATION OF ERROR MESSAGE CONTAINING SENSITIVE INFORMATION CWE-209
The affected application improperly handles error while accessing an inaccessible resource leading to exposing the system applications.
CVE-2024-41984 has been assigned to this vulnerability. A CVSS v3.1 base score of 2.6 has been calculated; the CVSS vector string is (CVSS:3.1/AV:A/AC:H/PR:N/UI:R/S:U/C:L/I:N/A:N).
3.2.6 INSUFFICIENT SESSION EXPIRATION CWE-613
The affected application does not expire the session without logout. This could allow an attacker to get unauthorized access if the session is left idle.
CVE-2024-41985 has been assigned to this vulnerability. A CVSS v3.1 base score of 2.6 has been calculated; the CVSS vector string is (CVSS:3.1/AV:A/AC:H/PR:N/UI:R/S:U/C:N/I:L/A:N).
3.2.7 USE OF A BROKEN OR RISKY CRYPTOGRAPHIC ALGORITHM CWE-327
The affected application support insecure TLS 1.0 and 1.1 protocol. An attacker could achieve a man-in-the-middle attack and compromise confidentiality and integrity of data.
CVE-2024-41986 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.4 has been calculated; the CVSS vector string is (CVSS:3.1/AV:A/AC:H/PR:N/UI:N/S:U/C:H/I:L/A:L).
Siemens reported these vulnerabilities to CISA.
- All affected products: Update to V2506 or later version
- (CVE-2024-41979) All affected products: The SmartClient should be operated in a secured network and context only
- (CVE-2024-41979) All affected products: Remove all tools giving possibility to call SOAP-services outside from the SmartClient
- (CVE-2024-41979) All affected products: The hardening instructions mentioned in the products security concept should be followed
- (CVE-2024-41980) All affected products: Harden LDAP-interface secure protocols by enabling the SSL-flag on configuration and a proper setup of your TLS-configuration
- (CVE-2024-41980) All affected products: All the users (including in LDAP) should be given the least privileges required
- (CVE-2024-41982) All affected products: Limit the permission to access those fields using the least privilege strategy
- (CVE-2024-41983) All affected products: Do not use original table structures and accounts for reporting. Create your own reporting accounts which have access via synonyms forwarding on views representing access to result-sets the user may use for evaluation
- (CVE-2024-41983) All affected products: Use DB-tools to limit load on productive systems for reporting accounts or use offline systems for reporting
- (CVE-2024-41983) All affected products: Harden your IIS
- (CVE-2024-41983) All affected products: Prevent any scanning of structures and configurations
- (CVE-2024-41983) All affected products: Limit the information to prevent to the end-user based on the need-to-know-principle to the minimum possible information
- (CVE-2024-41984) All affected products: Hardening of the solution, including the OS and IIS, is required, with specific measures such as hiding the IIS version to enhance security
- (CVE-2024-41984) All affected products: Users should not have the possibility to scan folders and extensions of files allowed to open should be limited to the required one
- (CVE-2024-41986) All affected products: Disable all protocols (SSL v2/v3, TLS 1.0, TLS 1.1) the solution should not use.
- (CVE-2024-41986) All affected products: Ensure, TLS 1.2 is enabled if you plan to use TLS 1.2.
- (CVE-2024-41986) All affected products: Follow the instructions of the security concept of Opcenter Quality and vendors.
For more information see the associated Siemens security advisory SSA-382999 in HTML and CSAF.
- August 14, 2025: Initial Republication of Siemens ProductCERT SSA-382999
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-226-06
