Rockwell Automation FactoryTalk Optix
Sep 9, 2025, 4:46 PM UTC
  • CVSS v4 7.3
  • Equipment: FactoryTalk Optix
  • Vulnerability: Improper Input Validation
Successful exploitation of this vulnerability could result in an attacker achieving remote code execution.
The following version of FactoryTalk Optix, a scalable, cloud-enabled visualization platform, is affected:
  • FactoryTalk Optix: Versions 1.5.0 through 1.5.7
A security issue exists within FactoryTalk Optix MQTT broker due to the lack of URI sanitization. This flaw enables the loading of remote Mosquito plugins, which can be used to achieve remote code execution.
CVE-2025-9161 has been assigned to this vulnerability. A CVSS v3 base score of 7.1 has been calculated; the CVSS vector string is (AV:N/AC:H/PR:L/UI:R/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-9161. A base score of 7.3 has been calculated; the CVSS vector string is (AV:N/AC:H/AT:P/PR:L/UI:A/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Rockwell Automation recommends users update FactoryTalk Optix software to Version 1.6.0 or later.
If users are not able to upgrade to one of the corrected versions, Rockwell Automation recommends following their security best practices.
For more information, see the Rockwell Automation security advisory.
  • September 09, 2025: Initial Republication of Rockwell Automation advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-252-04
