Rockwell Automation CompactLogix® 5480
Sep 9, 2025, 4:46 PM UTC
  • CVSS v4 7.0
  • Equipment: CompactLogix® 5480
  • Vulnerability: Missing Authentication for Critical Function
Successful exploitation of this vulnerability could result in arbitrary code execution.
The following version of CompactLogix® 5480 is affected:
  • CompactLogix® 5480: Version 32-37.011 with Windows package (2.1.0) Win10 v1607
A code execution vulnerability exists in the affected product. An attacker with physical access could abuse the maintenance menu of the controller with a crafted payload which could result in arbitrary code execution.
CVE-2025-9160 has been assigned to this vulnerability. A CVSS v3 base score of 6.8 has been calculated; the CVSS vector string is (AV:P/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-9160. A base score of 7.0 has been calculated; the CVSS vector string is (AV:P/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Rockwell Automation recommends users to implement best practices.
  • September 09, 2025: Initial Republication of Rockwell Automation advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-252-06
